Nearly 6 months since I played with this project, that's the drama with doing two projects at once.
So with the Monster waiting for an oil scraper ring or a Hi-comp piston replacement for the ST2 engine I decided to crack on with this for a bit.
This is the end result that I want for the rear end, so a bit more cutting and shaping was needed:
I cut the frame at the rear some more and made some shaped pieces to finish off where the frames meet:
Rear frame brace shaped and test fitted:
It looks a little like Frankenstein's Monster but it will be tidied up once it is properly welded :
With the exhaust mount in place:
With the bodywork fitted it looks okay:
It really is coming together....
Yorkie
