January 01, 2025, 08:06:27 AM *
News: Please Help
Pages: 1 2 [3] 4   Go Down
Author Topic: Frame Up Monster Build  (Read 11963 times)
« Reply #30 on: May 18, 2016, 07:17:49 PM »
My M750 carbie flywheel started out at 2052g, and ended up at 1726g after extending the trigger lump and a good bit of lathe work to lighten it.
I could have lightened it more, if I hadn't run out of time on the lathe I was 'borrowing'.
It's certainly not 'too light'.
I thought I weighed the Nichols unit, but I can't find that info.
IE flywheel would be easy to cut down.
clubhousemotorsports
« Reply #31 on: May 19, 2016, 08:03:54 AM »
A 900ie with ignitec and FCR carbs would be good I am sure. I have built a few 800ie motors running the FCR's with both oem Kokosan ignition and an ignitec so it can be done either way. I am waiting on speeddog to be the test pilot on a ignitec unit using the crank sensor pick ups, no reason it should not work great. I have just not tried one yet.
Injection would also be fine and lower maintainance just not as much fun in use. If going this route I would base it off a 5am ecu not the 15m.
I also would say gearboxes are subjective on my 900's I prefer the closer ratio gearbox which was only used in the 900 monster S models. It is an easy upgrade when building motors as it is the 748 gearbox and is pretty much a drop in. If you are running higher speeds or lots of extended time at higher speed the higher overdrive may be preferred. For track or tight twisty stuff I will take the lowered gear version.
TitanMonsterS4R
« Reply #32 on: May 20, 2016, 05:40:09 AM »
Project beginning.....
Finding a ton of 99 M900 frames, anything I should know before pulling the trigger on one from that year?
is there a better frame model year to have?
« Reply #33 on: May 20, 2016, 09:59:24 AM »
99  is a hoop style ride height adjuster if you are running a s2r swingarm the later style frames with a superbike style rod might be an easier conversion.
TitanMonsterS4R
« Reply #34 on: May 20, 2016, 11:24:41 AM »
Thx Clubhouse
« Reply #35 on: May 20, 2016, 01:19:49 PM »
But, since all but the 2002 900 engines have 10mm engine mounting bolts and the later style 'ST-based' Monster frame (which readily accepts an S*R swingarm) runs the 12mm engine mounting bolts, you'll have to deal with a conversion there.
« Reply #36 on: May 20, 2016, 02:22:46 PM »
So pick up an 02 900 wreck and fit sss as the easiest starting point. Will it be a US reg or Aussie reg Titan? In Oz the frame is the bike and determines what you can and cant do. In Oz if you want a carbed 900 it will need a carbed 900 frame to get thru. If its a US bring over, then thats another matter.
TitanMonsterS4R
« Reply #37 on: May 20, 2016, 04:13:12 PM »
Will be a US bring over. Cant have the locals pokieman able to stop my hustle...
« Reply #38 on: May 20, 2016, 05:21:16 PM »
Cool, you're a free man. waytogo
« Reply #39 on: May 20, 2016, 07:44:07 PM »
My '01 750 had 12mm. mounting bolts, not sure about '00.  99 and older were 10mm. for sure.
Ah, SpeedyMoto frame slider fitment:
Monster 900    1993-00    09-0203
Monster 600, 620, 659, 695, 696, 796, 800, 1000, 1100, S2R, S4, S4R & S4RS    2001-    09-0201
2000 and older, 10mm.
« Reply #40 on: May 20, 2016, 08:47:15 PM »
Whoops.  Yes, 2001 had the 12mm also.  Sorry
TitanMonsterS4R
« Reply #41 on: May 21, 2016, 10:05:15 AM »
Awesome...the hunt continue
« Reply #42 on: May 25, 2016, 06:57:36 PM »
 popcorn
TitanMonsterS4R
« Reply #43 on: June 18, 2016, 08:42:42 PM »
Secured an '01 900 frame. It's black, will need some serious TLC. Just going to go with a very nice gloss black. I need to try and find an engine now. Going to read back through the thread to figure out which is best for my needs.
« Last Edit: June 18, 2016, 08:49:38 PM by TitanMonsterS4R » Logged
« Reply #44 on: June 18, 2016, 09:22:17 PM »
That frame is 12mm engine bolts, so '01 and later for direct bolt-up.
Pages: 1 2 [3] 4   Go Up
