Bright legal headlight bulb?
Started by Jordan, July 18, 2008, 07:38:37 AM
sert duc
You may run the risks, my friend, but I do the cutting. We cut down my percentage---uh, cigar?---liable to interfere with my aim.
The final measure of any rider's skill is the inverse ratio of his preferred Traveling Speed to the number of bad scars on his body.
uclabiker06
Piaa super plasma bulbs are the most HID looking non-HID bulbs...forget the others trust me.  Either get an HID conversion or the Piaa super plasma. Check out the bottom of this page:
http://www.piaa.com/Bulbs/Bulbs-H4.html
2006 S2R
2009 Smart
TobyDanger
I just put in the Phillips X-treme and it is noticeably brighter than stock, but my old hi beam had burnt out and fouled the inside of the bulb so it looked extra dim before.  $40 shipped from the UK for a pair.
-=TobyDanger=-
"@[=g3,8d]\&fbb=-q]/hk%fg"
metallimonster
Stupid Question- We use H4 headlight bulbs right?
Kopfjager
asado
uclabiker06
2006 S2R
2009 Smart
DucatiBastard
Give a man a beer, and he wastes an hour.
Teach a man to brew, and he wastes a lifetime.
2006 Ducati S2R 800, 2004 Honda Dream 50R, 2001 Kawasaki W650, 1940 BSA M20
metallimonster
Found some Sylvania Silverstars Ultras on ebay for 20 bucks.  They say 9003 HB2 or H4 compatible.  Are these the ones I want?
Here is the auction.
metallimonster
So I just picked up a single Sylvania Silverstar Ultra and put it in tonight.  I really like the white light and it is plenty bright for me. [thumbsup]
I did notice that when I was behind someone in a lower type car my light was right in the passenger cabin.  I pretty much have the light aimed where it should be but I put it where I feel comfortable with where it is aimed when I ride, not in the garage.   Should I leave it where it is at or lower it keep from pissing people off?
Kopfjager
Put yourself in the car, then make your decision.
Armor
Your owners manual gives exact measurements to aim the headlight.  Any time you adjust the suspension, you should adjust the headlight.
metallimonster
I've followed the manual and I think I like the headlight to be a little higher so I can see more of the road.  Obviously this is what is pissing people off.  I guess a better question should have been should I have it where I feel comfortable of where it is supposed to be.
c_rex
that's what High beams are for.  only use them when you don't have 3000+ lb. objects hurtling toward you at great velocity.   [moto]
