February 07, 2025, 09:57:23 AM *
News: Please Help
Author Topic: M900 Ducati performance dash kit with full size tach help needed  (Read 2066 times)
ducriderinct
« on: June 17, 2016, 03:00:02 PM »
Does anyone have an install sheet or possibly a link to an installation instruction write up for this? This is the kit that has the full-size tachometer with the aluminum face that houses the idiot lights. I have it listed on the receipt as part number F77050 by fast by ferracci. I believe it is a kit made by roadracing but am not entirely sure.
I guess my question is, can I simply plug this gauge cluster kit into the existing M900 wiring harness or do I need to re-pin the connector/reuse the wiring harness from the bike that the gauge cluster was previously mounted in?
Both bikes are 1996 M900's
« Reply #1 on: June 18, 2016, 03:02:41 AM »
Would you show the back of the gauges and wiring connectors?
ducriderinct
« Reply #2 on: June 18, 2016, 01:04:10 PM »
After some further research, it seems that this is the road racing kit, with a Ducati performance tachometer and not a Ducati performance kit.
It has the same connections as the stock cluster. Metal twist lock in hoe bottom center and a speedo cable connection. I can get a photo and post it up.
Sent from my iPad using Tapatalk
« Reply #3 on: June 18, 2016, 01:07:16 PM »
Likely plug n play except for the extra loom part of the tacho kit. Probably runs some wires to the ignitors.
greenmonster
« Reply #4 on: June 19, 2016, 04:52:32 AM »
It is plug and play.
IIRC, you have to transfer the idiot bulbs.
And the tach is connected to one of the ignition modules.
M900 -97
MTS 1100s  -07
