December 27, 2024, 10:38:59 AM
Waste of money .....
5
6
7
15
Topic: Waste of money ..... (Read 54545 times)
Re: Waste of money .....
Reply #60 on:
October 21, 2019, 12:27:08 PM »
More like Factory Pro numbers than Dynojet ay?
The 1100's torque curve is very impressive.
MonsterHPD
Reply #61 on:
December 09, 2019, 12:09:49 PM »
Evening, all.
I hope to find some more power for the M800 during the winter, and since the clutch is slightly marginal already with the stock motor, what would you recommend I do with the wet clutch on these bikes?
Stopintime, I assume you do not have a stock clutch on your hotrod?
Kind regards,
Torbjörn.
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
S2R 800 '07
Reply #62 on:
December 09, 2019, 01:38:53 PM »
Quote from: MonsterHPD on December 09, 2019, 12:09:49 PM
Evening, all.
Kind regards,
Torbjörn.
Oh no, no, no
Two broken clutches (large springs in the primary driven gear) which could have ended much much worse. Good idea, lousy engineering and even worse: a factory that won't realize/admit it. They have the same shit in Panigales.
I have a 750 clutch. More grabby, but that can be helped by grinding 10-15 grooves in the steels, in a fan pattern. The 696 clutch also fit (also without the springs).
MonsterHPD
Reply #63 on:
December 09, 2019, 02:43:03 PM »
I'll check the spare parts lists. I have no experience with any of those clutches, except changing the plates in my M800.
But it seems I'll be on ebay soon ....
MonsterHPD
Reply #64 on:
December 13, 2019, 09:33:58 AM »
Ever so slowly ST2-cam project is underway.
One of many projects my pal has started is a TT2-type project. It actually got started before the present Classic Sportsbike and Supermono racing took precedence. He did a "conversion kit" to put St2 cams in the the 695 heads. He´s not quite sure how this goes together, and I´ll have to chheck for myself when I get the M800 heads in pieces, but I suppose it will be something similiar to this:
20191213_180415
by
torbjörn bergström
, on Flickr
The alu spacer is to compensate for the difference on the drive side, and the narrow ring spacer is to compensate for the shorter cam bit on the cam cover side (does show too well in the photo).
I´ll do the basics before the top end comes completely off: Squish, valve pockets (ST cams simulated by "ST cam timing" inlet and exhaust, openingand closing, on the M800 cams (I think that will give a good indication, correct me if I´m wrong).
Let´s see what that brings.
MonsterHPD
Reply #65 on:
December 16, 2019, 12:30:57 AM »
I did y first attempt at a leak-down test yesterday, on the M800. Looking at the advice from Speddog and others (in the other thread) I started by checking the clocks by pressurizing the gauge without attaching the motor hose. It showed about a 1 psi difference at 90 psi, so I take that into account.
I only have a small China garage compressor, so 90 psi is all it can muster. Also, taking readings is a bit difficult becaus eth small tanka empties quickly, then the compressor starts again, increasing the pressure to 90 and some psi, and then slowly sinking again.
As a first attempt, I decided to test with the pistons at BDC.
Anyway, on the horizontal cylinder the gauges showed (corrected) 90/82 psi, for a leak rate of 9% acc to the gauge table, with very audible leak thru the inlet, impossible to seal by pressing the hand aginst the inlet port.
The vetical showed 90/84 psi, for a leak rate of 7%, most of it thru the exhaust port.
I have no reference for this test, but both the numbers and the very audible leakage was a surprise to me, especially on a bike that actually runs quite well. I will certainly do some more leak-down tests to see wher my other motors are, and how thi one will be after the top-end job.
Reply #66 on:
December 16, 2019, 05:21:37 AM »
MonsterHPD
Reply #67 on:
December 23, 2019, 06:45:34 AM »
I´ve spent the last few garage days making baseline tests on the M800 motor.
Squish on the vertical cylinder is between 1.05 and 1.20 mm, so not too much to be gained there.
Valve to piston clearance is pretty generous with the stock cam, remains to be seen what will happen with the St2 cam in place
M800 Standard_03
by
torbjörn bergström
, on Flickr
It really seems that the only thig needed to put the ST2 cams in the M800 heads is a 10 mm spacer on the drive side:
2019-12-23 14.50.20
by
torbjörn bergström
, on Flickr
In order to check for valve to piston clearance, I´ll have to do the valve clearances with the ST cam in place. A bit tedius but unavoidable.
A Merry Christmas to everyone,
Torbjörn.
Reply #68 on:
December 23, 2019, 05:58:40 PM »
Merry Christmas
Reply #69 on:
December 23, 2019, 09:07:08 PM »
What is the difference in the cam base circle between the OE M800 cam and the ST2?
MonsterHPD
Reply #70 on:
December 24, 2019, 04:28:59 AM »
Quote from: Duck-Stew on December 23, 2019, 09:07:08 PM
I don´t know, but the duration is almost 30° more on the ST2 cam, which hopefully can be translated into a bit more power.
Reply #71 on:
December 24, 2019, 06:59:19 AM »
Quote from: MonsterHPD on December 24, 2019, 04:28:59 AM
Base circle differences will affect shim dimensions or at worse valve stem length. It’s time to check that now. That way you’re not opening a larger can of worms than you expect.
MonsterHPD
Reply #72 on:
December 24, 2019, 07:03:56 AM »
OK, I see and thanks for the hint.
I don't think it's a problem since others have done this, but of course it's worth a check.
I'm in the process of installing the cams in order to check valve to piston clearance, so I'll soon know ...
Reply #73 on:
December 24, 2019, 01:09:02 PM »
Reply #74 on:
December 25, 2019, 01:40:07 AM »
Those cams have 1mm more lift. If they fit ok it will be interesting to see how the bike performs.
5
6
7
15
