Modular motor, my ass - A tale of two Fords
Started by Dirty Duc, January 21, 2017, 10:44:40 PM
Speedbag
Quote from: ducpainter on January 24, 2017, 04:40:33 AM
All that, and now throw in the production date changes in between.
There's a reason Ford parts guys drink. ;)
Heh.
Just the other day I deciphered some casting numbers for a friend to determine what exactly was in a '67 Mustang he bought. He was sort of amazed. Funny how that stuff sticks in your head.
It's sort of like a curse...
Quote from: Speedbag on January 24, 2017, 05:12:43 AM
Heh.
It's finally been long enough that some of the basic numbers have left my brain.
Some are still stuck there, along with prefix and suffix.
A curse indeed.
The C4 transmissions alone are enough to make someone a life-long alcoholic.
Finding a 302 mated to a standard trans is easy.  Just be sure to get a 5.0 instead of a 302.  WAY more common.
BTW:  The 302 in the Falcoon is a rebuilt 1990's Truck 302 mated to a late 80's T5 5-speed stick with a stock flywheel.
Quote from: Satellite smithy on January 24, 2017, 05:00:48 AM
I was looking for a 289 or a 302, ideally with a manual transmission already mated to it, just to make life easier.
the 302 I have was in an '85 Thunderbird originally and had an AOD behind it which is one of a couple sitting in some corner.
Quote from: Satellite smithy on January 24, 2017, 06:38:29 AM
They ain't the same thing?
Nothing is the same with Ford.
You could take the parts out of the same model and year, and they still might be different. [thumbsup]
Speedbag
Speedbag
Quote from: Speedbag on January 24, 2017, 07:07:02 AM
Poly or LA?  ;)  [laugh]
or Magnum, I'm sure those have some worthwhile differences from the LA
Quote from: Satellite smithy on January 24, 2017, 07:05:20 AM
I'm putting a 318 in this thing.
It runs.  It drives.  You're lying because Paula won't let you touch it and everyone knows it.   [laugh] [laugh] [laugh]
Dirty Duc
So it turns out there was a running change on the connectors for the coils... new coils fit the older harness, not so the reverse.
Already can't find the later coils from the 4.6 [roll]
Quote from: Duck-Stew on January 24, 2017, 03:54:33 PM
No, no, this is for the other car.
Building two is just...twice the work.
Quote from: Satellite smithy on January 24, 2017, 07:41:59 PM
Why bother a 318? Just slop an LS3 into it & be done with it...
