Monster 800 Immobilizer Hex Address
Started by ajw85, January 31, 2017, 08:10:19 AM
Danknugz420
ajw85
#16
Quote from: He Man on September 11, 2020, 07:22:04 AM
THis is pretty useful information. I have been trying to disable my immobolizer using online guides for a while now. I could never really figure out how someone determines that they are at the right location for the hex values of the immobilizer.
I have "unlocked" my ECU for mapping (based on what i was told by the tuner) but the immobilizer is still active. I am afraid to access write anything to the ECU using ducatidaig simply because the tuner had problems getting the map to "stick".
But this is great info and I guess I should just bite the bullet and spend some time browsing the bin files!
Edit: See latest post
I actually found that the hex address location changes among all the ECUs, even among same models, but you if search for "97 00 A5 2E E0 13 88 07 6C" the immobilizer address location is the next byte. I hope this helps someone! I'm going to edit my reply above so people don't possibly brick their ECUs. If you need help, shoot me a PM.
ajw85
Hey me again,
I was browsing through another bin and it looks like if you search for "97 00 A5 2E E0 13 88 07 6C" it won't find the immobilizer byte properly as a few bytes change with year and model.
You should actually search for "97 00 A5 2E E0" or "9700A52EE0" and then count 5 bytes over and that one should be an "01" if the immobilizer is enabled. Change it to 00 and you're set.
ex
97 00 A5 2E E0 13 88 07 6C 01
SSDirtyDuc
I'm having the same issue with my 2007 s2r1000. I have the cable and software just haven't figured out exactly which Line is the immo… help would be great because It will not start and it's killing me…
