Lithium Battery charger for non Shorai brands
Started by koko64, June 16, 2017, 02:39:39 AM
chipripper
I'll be wiring it up tonight. The only "downside" is it charges through the main terminals, and discharges individual cells through the balance cable. So I will need to wire up the old style battery pigtail and the balance cable to do balance charging with the tank down. Not really a big deal for me.
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
