I'm ditching Photobucket. What to use instead?
Started by Monsterlover, July 08, 2017, 04:00:27 PM
GK
When I think about how many pics I've posted, here and on other forums over the last dozen or so years, I get hacked off to the max.
Mongrels!
2001 Ducati  Monster 900S ie
Gone but not forgotten!
Tried again to download an album and couldn't.  I emailed in to photobucket and this is what they sent back -
Photobucket Team (Photobucket Support)
Jul 25, 10:11 AM MDT
Hello,
Thank you for emailing us. There is a known issue with the album download feature and our team is currently looking into it.
In the meantime, you can still download your images with the following steps:
    Step 1. Login to your Photobucket Account
    Step 2. Navigate to your library page
    Step 3. View a photo and click the download button
    Step 4. The picture will be saved to your computer
Thank you for your patience at this time.
Best,
Photobucket Team@Photobucket Support
Kopfjäger
Anyone find a good solution for posting from a mobile device yet? I have all my pictures saved elsewhere, so I don't need to move anything from Photomake the beast with two backset.
Who has used Flickr? Im trying it. Strange terminology.
Quote from: koko64 on July 29, 2017, 08:14:31 PM
I have it a shot on mobile. Couldn't figure out how to post from my phone
What about Imgur?
Kopfjäger
I can't figure Imgur out on the iPad either. But I'm dumber than a bag of hammers.
I use flickr from a lappy or desktop.
I'd be a lot happier with it if they stopped dicking around with the look and layout and procedures every year.
I tried to use it on my android phone, but it won't work here (or I can't make it work).
I'll give Flickr a good go.  Just gotta set up the right privacy level and learn to post pics here. Pussbucket was easy that way.
Ok, I can post image links but not direct pics via Flickr. It's a step forward I guess.
S21FOLGORE
#40
Click on the image you would like to post here,
Click on “share photo”, which is located lower right corner.
Click on “BBcode” and copy it, then, select size.
Come back to the forum, paste what you just copied.
Delete the part before img]  and after [/img
Then, post it.
Thanks. I'm trying to do this but missing a little detail somewhere. I'll have to check over my process.
chipripper
2008 S2R1000 black and white, mostly stock ;-)
Marving header, Velocity stacks, Pod filters, Flashed ECU to DP map, Polished valve covers and cam covers, SSR reverse shifter and inspection cover, Aelle adjustable pegs, Windscreen and cowl removal, Many plastic bits removed, Cut beer tray
