December 27, 2024, 08:32:13 PM
Statler
The Ecoboost thread
11
12
13
14
18
Topic: The Ecoboost thread (Read 47435 times)
The Architect
Re: The Ecoboost thread
Reply #165 on:
March 30, 2018, 12:27:24 PM »
Quote from: ducpainter on March 30, 2018, 10:26:24 AM
Just ordered a factory trailer brake controller, the ODB dongle, and downloaded the software to activate the TBC module so it will work, and display on the screen.
I had to google this................
So what software did you use?
http://www.livefreeballistics.com
The Architect
Reply #166 on:
March 30, 2018, 12:28:42 PM »
It just hit me!
TURBO BOOST MODIFICATIONS!!!!!!!
For $50 you can touch my
Reply #167 on:
March 30, 2018, 01:10:59 PM »
And here I am....enjoying the luxury of the current winter truck having a roof.
Given that the Jeep had no top when I got it.....and it's what I used in the winter.
Never again.
Reply #168 on:
March 30, 2018, 01:31:54 PM »
Quote from: The Architect on March 30, 2018, 12:27:24 PM
I haven't done it yet...
FORscan
The best kind of whore is a
Reply #169 on:
March 30, 2018, 04:02:52 PM »
Keep us posted on how that goes for you.
Reply #170 on:
March 30, 2018, 04:09:53 PM »
Quote from: Monsterlover on March 30, 2018, 04:02:52 PM
Will do.
If it doesn't work, I'm out $30.
I'm willing to take the chance.
duccarlos
Reply #171 on:
April 02, 2018, 08:22:04 AM »
Quote from: ducpainter on March 30, 2018, 04:09:53 PM
Will do.
There's a free version of FORScan that you could use to make sure that it's compatible. You would only be out whatever you paid for the ELM327 OBDII.
Reply #172 on:
April 02, 2018, 09:05:12 AM »
Quote from: duccarlos on April 02, 2018, 08:22:04 AM
That's the version I have. I've seen YouTube vids of people doing it with the FORscan free and the ELM327.
The ELM is only $30.
duccarlos
Reply #173 on:
April 02, 2018, 09:15:03 AM »
There are even cheaper ELMs available. Seen some for as cheap as $9, even though I would question their quality.
Reply #174 on:
April 02, 2018, 10:00:26 AM »
Quote from: duccarlos on April 02, 2018, 09:15:03 AM
This is the one that was recommended on the FORscan forum. It has a toggle switch that allows it to access more functions.
It arrived today. I downloaded, and installed, the drivers without issue. The TBC module is due Friday.
I'll likely spend a few minutes playing with the software to create a vehicle profile and see if I can access the IPC module which is where the changes in config need to be made.
duccarlos
Reply #175 on:
April 02, 2018, 10:07:04 AM »
FORScan thankfully comes with most, if not IPCs for the newest Fords
Reply #176 on:
April 02, 2018, 11:20:00 AM »
Quote from: duccarlos on April 02, 2018, 10:07:04 AM
The vids I saw made it look really robust, and easy to use.
I'll find out.
edited to add...
The FORScan program, as distributed, wouldn't allow me to make any config changes. Kept telling me I needed an extended license. I registered on the forum, downloaded and applied the extended license. The license in valid for 60 days and can be re-upped indefinitely.
Haven't tried to access those areas again, but I don't see any issues.
Last Edit: April 04, 2018, 04:28:33 AM by ducpainter
Reply #177 on:
April 09, 2018, 02:38:20 AM »
Worked slick as snot.
Installed the control, opened FORScan, modified the parameters, and cleared all the old DTC codes. The truck had a low voltage issue at one point. Maybe someone left the key on? When I activate the slider on the control the truck tells me no trailer is connected.
I'll check it in a week, or so, and see if the thing is throwing codes.
duccarlos
Reply #178 on:
April 09, 2018, 07:30:54 AM »
Reply #179 on:
April 20, 2018, 04:58:20 AM »
How's that truck working for you DP?
11
12
13
14
18
