Thanks, Howie. I'll do a voltage check just for the heck of it and see what I get.
Regarding valve gap...pretty sure I was dead on for TDCC. Regardless, the DR650 doesn't need pure, spot-on, TDC for valve check. There is a small bandwidth where the valves are in the right position.
So this what the DR guys said regarding too wide of a gap:
And realise that the valve clearances affect valve lift and duration... obviously lift and duration decrease as clearances increase. That being said the decompressor mech only slightly decompresses the engine so if your clearances are way off the decompressor does very little to nothing depending on the extend of the incorrect adjustment.
So I think what that means is that the engine wasn't decompressing enough. Thus the blowback through the airbox.
