Ducati GP18 Livery
Started by duccarlos, January 15, 2018, 07:25:11 AM
bdfinally
Anyone know what the metal thumb "doodad" directly below the off button is. I know the rear thumb brake is on the other handlebar.
Quote from: bdfinally on January 22, 2018, 12:35:47 PM
It's a neutral lockout, sequential transmissions have neutral at the bottom.
Quote from: Speeddog on January 22, 2018, 02:58:11 PM
I want one of those... ;D
The KD90 that I learned to ride on had neutral at the bottom.
All good until I went for one downshift too many.
duccarlos
Quote from: Speeddog on January 22, 2018, 04:18:10 PM
I can't picture how that works.
Why are there 2 reservoirs on the clutch side?
Quote from: duccarlos on January 22, 2018, 04:25:36 PM
They just 'swap' the 1st and Neutral groove profiles on the shift drum.
Quote from: NAKID on January 22, 2018, 07:10:48 PM
One for clutch, one for rear thumb brake.
bdfinally
So they roll up to the grid, once the flagman comes off the track you put it in gear, lights come on and press the lockout?
Weren't they 3 speeds?
Quote from: ducpainter on January 23, 2018, 04:57:57 AM
Mine was a '74, and was 5 speed.
Quote from: bdfinally on January 22, 2018, 08:26:06 PM
AFAIK, pushing the lever allows for shifting from 1st to neutral.
Otherwise the same rider interface as a conventional transmission as far as shifting goes.
bdfinally
