« on: May 24, 2018, 05:53:11 AM » |
Has anyone ever attempted to remove the original plastic lens on their gauges? Ive got an S2R1000 and this is the year i finally get the damn thing working right (I gave up 2 years ago and stopped riding street).
Id like to swap it out for a flat glass lens, but it looks like the plastic is either press fit or held in with glue and needs to be cut out.
I also need to do is replace the stepper motors because my speedometer died (and wont pass inspection). has anyone here done that? I found the motor on ebay and bought a few just in case someone else needed them.
« Reply #1 on: May 24, 2018, 12:23:38 PM » |
Stepper.... speedo... what's the connection?
The lens is hard to remove. Any luck sourcing a used lens?
thorn14
« Reply #2 on: May 24, 2018, 01:19:37 PM » |
Isn't it curved slightly to accomodate the needle inside?
M620 turned M800 but then back to M620 after the M800 died at 110k, and now to Multi 1000.
« Reply #3 on: May 25, 2018, 05:14:38 AM » |
A stepper motor is a type of motor that can discretely be positioned at an equal point along it's rotation rather than a traditional motor that only spins.
The motor that moves the needle is a type of stepper motor since it can move to a discrete position and hold it.
The glass is curved, but I didn't immediately flag it as needing to bypass the lens. I'll reassemble and check. If the lens is just press fit, then cutting it out might be the only choice. I could also make it out of plastic too so it's not scratched anymore.
thorn14
« Reply #4 on: May 25, 2018, 01:10:44 PM » |
If it has clearance I would just remove the old glass whatever way doesn't crack the bezel around it and epoxy in flatstock like you propose. I almost did it once myself but the gauges got smashed to the ground before I had a chance.
« Reply #5 on: May 25, 2018, 01:21:57 PM » |
............ The motor that moves the needle is a type of stepper motor since it can move to a discrete position and hold it. .........
I thought about the throttle stepper. There was a discussion about cracked lenses years ago. I think the consensus was that the lenses cracked because of temperature changes and vibrations which they were too tightly fitted to withstand Use silicone?
Heath
« Reply #6 on: May 25, 2018, 03:31:27 PM » |
I always thought it was curved to reduce glare.
2007 Ducati Monster S4RT 2006 Ducati Monster S2R800 Dark [sold]
« Reply #7 on: June 18, 2018, 12:03:25 PM » |
got the motors in, swapped them out and my speedo finally works after 4 years.
I bought 4 motors because i was going to replace both at the same time and wanted spares, but I ended up only replacing one and realize I dont need so many spares.
Does anyone else need to repair their gauges? I could do it for you for a small fee, or you can do it yourself. Its pretty straight forward.
« Reply #8 on: June 18, 2018, 01:07:09 PM » |
Good work
ajw85
« Reply #9 on: June 18, 2018, 01:56:01 PM » |
Also interested in this.
I was thinking laser cut the plastic out or heat gun and press out. I know there are lots of gauges that need to be fixed out there
thorn14
« Reply #10 on: June 21, 2018, 09:59:30 AM » |
Probably more likely.
ajw85
« Reply #11 on: June 26, 2018, 07:50:40 AM » |
Did you end up repairing the cracks in your gauges? got the motors in, swapped them out and my speedo finally works after 4 years.
« Reply #12 on: June 26, 2018, 10:54:32 AM » |
Nope. I tried a heat gun and the glue just wouldn't melt. i have to carefully cut it out and use the original lens as a shelf to support a new lens.
its riding season right now, and i rather have ZERO down time! In the winter ill fix it.
