July 27, 2024, 07:19:45 PM
07 s2r 1k heavy clutch, can you make it less heavy; ATCP? Installed Oberen C Sla
Topic: 07 s2r 1k heavy clutch, can you make it less heavy; ATCP? Installed Oberen C Sla (Read 3695 times)
Re: 07 s2r 1k heavy clutch, how can you make it less heavy; swap with ATCP?
Reply #15 on:
June 21, 2018, 10:54:23 AM »
Ive done the 2 spring trick but went back. The only way to know if your clutch pack has enough normal force to get the proper engagement is to dyno the bike and see if there is any difference in power loss between the two (before you start cooking clutches left and right).
Im assuming you already have aftermarket slave cylinder and levers right? Theres also changing you ergonomics by having bar risers so your arms sit higher.
DuciD03
.... when did that happen...?
BTW: thats a bad pic of Bono, not me .... ;)
Reply #16 on:
July 18, 2018, 09:36:32 PM »
AND to follow up on the discussion and suggestions .... just finished installing an Oberan clutch slave; ....omg...; its now so overly easy to pull that clutch now! I'll try er without adding back the 2 springs for the moment; mostly so theres less rear wheel lock on downshifting; ... but wooooohoo nice and easy to pull now! yea! ...and one s**t grinning big
Last Edit: July 18, 2018, 09:38:10 PM by DuciD03
.... all the world is yours.
Reply #17 on:
July 19, 2018, 12:36:29 AM »
