thoughts on a potential purchase - pickup on or around Fri 24-Aug
Started by MN1200S, August 03, 2018, 09:22:38 AM
Quote from: MN1200S on August 27, 2018, 08:16:57 AM
Just noticed. . . blast it, these pix worked when I originally set it up, followed the directions for shared Apple pix after trying and preferring to use DropBox. Hard to believe what a pain pix seem to be here. Back to the drawing board again, later today.
Any legitimate link from a host that you include in between the image tags will show up here. You just need to figure out the actual location of the pic on your hosts site.
We don't host pics.
Right click on image in Dropbox, select 'copy image location'
Click image button above, paste in the gap [im g]    <paste here>      [/img]
Presto
MN1200S
So is the post "Preview" to be trusted ie. if it works there it's good and if not then don't continue?  I'm using Chrome if that matters, and had numerous attempts not work in preview (and I aborted) and had one work correctly in preview and ultimately fail after completed.
Is there a practice forum or better place for these administrative conversations?
Thanks
Quote from: MN1200S on August 28, 2018, 08:34:41 AM
Thanks
Preview won't always work because of your computer cache.. Keep in mind that Google, and Amazon will cache photos on your box, so you can see it but others can't. The share location is keyed to you so they can track your usage, but isn't the actual location of the pic.
If you have questions about the mechanizations of the software use the Board Tech Issues forum, or pm me.
I'm not as grumpy as all these kids think. ;D
