M900 Carbie X-Pipe Mod
Started by dlearl476, August 03, 2018, 06:25:32 PM
dlearl476
#15
I got a chance to discuss this a bit more with my buddy/mechanic who's done it in a number of bikes. He said the biggest difference between welding a flat piece on each side vs four sections of pipe is felt in the wallet.
Yes, low end grunt is preferable, but at the speed I ride, it doesn't really matter anymore.
I used to have a 2-1 Galasetti pipe that I bought from Raux years ago. I never dyno-ed the OEM exhaust as I've never had it on my bike (had the RR exhaust on it when I bought it) But after I put the FCRs on, I dyno-ed the Galasetti vs the RR and the Galasetti had about 5 more hp on top and the RR about 5 more ft lbs of torque between 3500-5000 where I do 90% of my riding.
But it's too make the beast with two backsing loud. And not just loud, shitty loud. If it was 110db of Termigoni goodness, I'd keep it, but it sounds like a make the beast with two backsing '92 Datsun with a broken muffler.
I bought a pair of Conti copies off the list last year and I want to use them, and my buddy suggested as long as I'm using a stock header/XPipe I aught to mod them. If I can find a place I trust to do the flat piece mid to them, I'll do it. If not, I'll just use the OEM pipe as is. Like I've said, won't make a heck of a lot of difference on my 50 mile canyon runs.
I tell you though, I'm sure going to miss the clean look of the RoadRacing pipe.
dlearl476
Quote from: koko64 on August 04, 2018, 02:07:59 AM
The stock pipes are surprisingly good. There is a link to a spaghetti Vs oem system and the bang for bung ain't worth it. The spaghetti system gains a couple of hp at the very peak but that's it. Throttle response may improve but I don't have FHE on that. I'll look for a link from Doug Lofgren. Maybe a racy system might help with other big mods. Stain tune once made a system with that type of enhanced crossover and larger diameter pipes. Maybe 45mm iirc. I lost the catalogue.
Oh, I forgot to mention, spaghetti pipes are as expensive as hell, and mostly good on the top end. Not really appealing to me, although they look cool.
dlearl476
Thanks for all your input, guys.
If I can squeeze my buddy for some cheap dyno time I'll do a comparison between the RR and the Conti reps to add to the data base.
Great to see the charts. Cheers [thumbsup]
greenmonster
Quotethe stamped restriction and weld in flat metal with basically the same effect as that pictured."
I did that. Maybe a little more grunt at lower revs but not worth the trouble.
Rejetting not needed.
Bad memory, l had the crossover flat cut out, had a 30x30mm
square piece in middle, the rest was flat.
M900 -97
MTS 1100s  -07
