DSS cush drive "pins" fall out?
Started by cmross13, November 07, 2018, 12:04:23 PM
cmross13
Quote from: Speeddog on November 08, 2018, 12:02:56 PM
Keep in mind the '25mm axle' wheel's rim is ~4mm offset relative to the hub compared to the 17mm axle...
You're doing it the hard way, but have at it!  [thumbsup]
would you care to elaborate on either of these statements?
A: are you saying that the hub centerline of two wheels of the same width is different? this will require some engineering but im sure i could figure it out. unless...
B: you recommend an easier way?
2007 S4RS, 2000 M900ie
