January 20, 2025, 08:16:59 PM *
Pages: 1 [2]   Go Down
Author Topic: Mid Ride Shutdown with Oil Light!!!  (Read 4710 times)
Wrath of Jon
« Reply #15 on: May 26, 2019, 01:09:46 PM »
Took the tank off and checked the lines and they seemed to be good to me.
Tried to check the spark plug but I need a 3/8 to 1/2 socket adapter to reach the plug.
Measured the coil plugs resistance and it was about 1.2 ohms I think, the service manual says it should be 650 +/- 50, but still dont see why that would have caused it to shut down mid ride like it did.
2004 Ducati Monster S4R
Wrath of Jon
« Reply #16 on: June 08, 2019, 10:28:41 AM »
Put a bottle of HEET into the tank ,added some 91 octane, and adjusted the fuel pressure regulator and the bike fired up for me!!!
Now the red light is still on though and it won't go off after driving around town a bit so I am scared to take her anywhere still
« Reply #17 on: June 08, 2019, 11:40:26 AM »
Please.
Stop running the motor.
The next time you start the motor absolutely have a gauge connected to check the oil pressure.
Please.
« Last Edit: June 08, 2019, 11:42:50 AM by Speeddog » Logged
Wrath of Jon
« Reply #18 on: June 08, 2019, 12:21:11 PM »
I dont know what pressure I'm looking for if I do hook a gauge up to it
« Reply #19 on: June 08, 2019, 12:26:04 PM »
Scroll back in this thread.  I gave you the specs.
Wrath of Jon
« Reply #20 on: June 08, 2019, 12:56:14 PM »
oh lol doh!
Looks like I'm going to have to get one online as I can't seem to find it in town.
Would something like this https://www.amazon.com/Shankly-4350330500-Oil-Pressure-Gauge/dp/B07GYBWQC2/ref=sr_1_1_sspa?crid=T5NH3DS26CPW&keywords=oil+pressure+gauge+kit&qid=1560023254&s=gateway&sprefix=oil+pressure+guage+%2Caps%2C164&sr=8-1-spons&psc=1 work for me?
« Reply #21 on: June 08, 2019, 01:18:39 PM »
If that has an M10x1 threaded fitting.
Wrath of Jon
« Reply #22 on: June 09, 2019, 10:07:13 AM »
Sure does, thanks
Wrath of Jon
« Reply #23 on: June 13, 2019, 04:07:36 PM »
So just tested the cold start pressure and I'm getting 6 bar idle to 7 bar when revving up
Warmed up I'm getting about 4 bar at 1000 rpm and up to 6.5 while revving
Only revved to 4000rpm
Sent from my VS995 using Tapatalk
« Reply #24 on: June 13, 2019, 04:41:44 PM »
Doesn't seem to be an oil pressure problem.
Wrath of Jon
« Reply #25 on: June 13, 2019, 07:28:38 PM »
Well I couldn't help myself.
I took it out for a decent ride and just unplugged the oil pressure switch, so the light would stay off. Rode just fine. Guess it really is just the switch?
« Reply #26 on: June 13, 2019, 08:58:02 PM »
Yes.
Wrath of Jon
« Reply #27 on: July 02, 2019, 05:39:01 AM »
So I ordered a new oil pressure switch from Ducati of Omaha and it's acting the same as the old switch...
« Reply #28 on: July 02, 2019, 05:50:28 AM »
Is the connector making good contact?
You can, carefully, use a pick to slightly bend the female spade connector to tighten it. If there's no plastic protector, you can use pliers.
Wrath of Jon
« Reply #29 on: July 28, 2019, 05:08:07 PM »
So after trying to use compressed air and dielectric grease. I just used some WD40 contact cleaner on it and it's working fine now. This is the new one thats working. I'll try putting the old one on later and see if it works now too.
Pages: 1 [2]   Go Up
