You're too stupid to... own a diesel small truck...so we're thinking electric
Started by Zaster, July 12, 2019, 12:20:48 PM
Quote from: Speeddog on July 12, 2019, 12:49:57 PM
More than 500VDC at 2000A.
A bit of searching says that would require 4 of ~1" diameter stranded copper wires, well actually 8 as there's + & - conductors.
That sounds a bit cumbersome.
I'm wondering what kind of sound a 20kW wireless charger would make.
GreasySnipe
Megacharger territory, over 1 MW.
Over 1341 HP.
Any folks with utility power experience care to comment on how feasible that is?
The Data center I work in has an average daily load of 750 KW and it's emergency generators(Mirrless Blackstones, which are old btw) run 480 3 phase, 60hz @900 rpm. They put out 1 MW maximum. The Data center I used to work in had 3612 Cats rated at 2.6 MW, 4160 VAC @ 900 rpm each at max load.  2K amps @480 VAC 60hz would require a 1.3 MW input, The arc flash rating alone would make this kinda unfeasible in my thoughts.
2011 Monster 796
2012 Street Fighter
2013 848 Evo
2016 Monster 821
2022 Scrambler Nightshift
2023 Triumph Speed Triple 1200 RS
2023 Monster 937 SP
