1997 M750 Vertical Cylinder Rich
Started by greencow, August 16, 2019, 07:47:30 PM
greencow
Got the carbs on the bench, upon closer inspection, looks like the PO fitted a Dynojet needle and spring.  4th groove down from the top.  Definitely not the stock Mikuni needle, this one is tapered, and has more grooves than stock.
Other than that, the needle jet looks pretty good still, maybe slightly ovaled.... Very hard to tell, if it is, it's minuscule.
The choke/enrichment plunger looks in good shape.
Side note, the slide housing o-ring fits a little sloppy.  I used a KL supply kit to refurb these carbs, if that o-ring is ill-fitting, could that cause excess fuel to bypass the needle jet/slide housing?
Perhaps, but I've not seen that happen.
Check the rubber tip on the float valve needle.
I had one with a small blister on it, very troublesome.
Quote from: greencow on August 17, 2019, 01:17:46 PM
Fuel tap?  Are you talking about the fuel petcock?
I replaced the vacuum petcock with a manual one, then capped off the vacuum line to the horizontal cylinder with a rubber nipple.  The only other vacuum line running from the vert cylinder is going to the fuel pump.
[thumbsup]
greencow
So, while I had the carbs on the bench, gave 'em another thorough cleaning.  While I was taking them apart, noticed a LOT of gas on surfaces I wasn't expecting to see it.  Mainly the slide housing, in and around it.  I had drained the carb bowls before taking them off, so that stumped me a bit.
The only thing that was causing some concern, to me, was the new slide housing o-rings.  Fitment was super sloppy, and the o-ring itself was to large, in diameter.  Threw the old o-rings back on there, just for giggles.
Put about 60 miles on the bike so far, and it's definitely running less rich.  Vertical plug is still a tad to rich, for my tastes, before however, it would foul out with soot after a 15 minute ride.  To the point that I could scrape off a layer of it.
So, dunno for sure if that was problem, as of right now, seems to be.  I changed nothing else since having the carbs off the bike.  Still gonna throw some new needle jets on there, once I get them.  I'll keep you gents updated, thanks for all the input guys!  [thumbsup]
 [thumbsup]
Those o-rings should be a tight fit so it's good you put the old ones back in. They take a set over time and not all rebuild kits are equal. I leave them be if they look ok, but change most of the others if required. Needle jets should be replaced with Factory Pro needle jets as oem can wear quickly. Look up the Dynojet site for needle position recommendations for your modifications.
greencow
So, just to keep this thread updated in case anybody else comes across issues like this.
Been chasing my tail for over a year with this problem.  After the carb rebuild kit, new needle jets (emulsion tubes), brand new ignition coils from CA cycleworks, etc....  I was still having rich issues, to the point of changing plugs every few hundred miles, or the bike would run like garbage.  Point of note, didn't really have this problem until I did the carb rebuild kit originally.
Bought the full kit from Litetek, just had the bike out for a spirited ride, and boy does it ever run great.  Time will tell if that was the problem, but seeing as this only started to crop up after using crappy, ill-fitting seals from the first rebuild kit, I'm leaning towards yes.  Pulled hard, felt great all through the powerband, and no more rich puffs of smoke from the exhaust.  Props to Litetek for a solid kit  [thumbsup]
Well that seems to back up what I'm seeing. Customers using cheap knock off kits are getting the level of performance they paid for. There are plenty of rebuild kits on ebay of questionable quality at too good to be true prices. Avoid "unbranded" crap.
If oem gaskets and o-rings are in good shape I leave them be. Quality kits from reputable mfrs are pricey, but the only ones worth using. The longevity of oem components is quite remarkable and the needle jet seems to be the main wear item in BDST carbs.
I serviced a dirt bike FCR recently and it was so badly clagged from sitting in old fuel that every jet was blocked and the float bowl was full of blue gel. Disassembly and thorough cleaning both manually and with a sonic bath restored it. Every rubber part was good and stood "proud" of the gasket surface. Incredible quality. The only part replaced was the float needle as I couldnt envisage how to clean it in a timely way without dissolving the rubber tip. I noted how expensive the genuine kit parts were.
pepeducat
There is also the phantom O-ring which can interfere with the carburetion.
It is an O-ring internal diameter 5.5mm and toroid of 1.8mm.
greencow
Yah, that's the pilot merge cavity o-ring I believe.  Pretty sure that wasn't even included in the first "kit" I put in the carbs.  The Litetek kit comes with a pair.
greencow
#24
I'mmmm baaaaaack.  Long story short, bike was still fouling out plugs, not as quick as before, but still worse than when I first bought the SOB.  My last resort was throwing all new jets at it (thought maybe I had reamed them out when cleaning the carbs....maybe?), and a new(used) set of choke plungers.
Originals were looking     :-[[puke]
Bike fired up much faster, gonna throw some new plugs on it and cross the fingers....
**EDIT**
After a couple hundred miles of riding the plugs are finally looking how they should, or at least much better.
That right plug has maybe 200 miles on it, I wire brushed it clean at some point too, still fouled up in no time.
The airbox is drilled and not cut open, correct? 140 main jets? What pilot jets were you using again?
greencow
Whoa, sorry koko, somehow overlooked this.  The airbox was delidded.  I rigged up a cover that slip fits over the filter and reduces the intake to roughly what a drilled air lid would be.
Correct, 140 mains and 40 pilots I believe.
Funny enough, the problem has never truly went away, sometimes it would be fine, and sometimes the bike would run like crap, either pig rich or dropping the vert cylinder. It would happen when cold, hot, short ride or long, didn't matter. Went back and resynced the carbs (they were a bit off), set the idle and enrichment screws properly, ran like a champ right after then straight back to the problems.
Finally tracked down one of the issues at least. I'm hoping when I fix the pickups it'll fix the running rich issue.  Seeing as they weren't technically dead, just randomly dying as the heat/vibrations caused the wires to short together.  That was a fun little hidden problem to track down. Resistance would read fine on the meter hot/cold. Had to start reefing on the wires will holding the meter to the plug and finally saw the resistance drop to nil.
Thanks for the update.
So the failing pick up would cause a misfire on the rear cylinder causing it to load up with unburnt fuel and foul? That's quite unlucky! Concurrent issues are difficult. One issue was a stable fuel issue and one an intermittent ignition issue, so difficult to diagnose. A lot of moto workshops would struggle with that one.
Once the bike settles down to predictable behaviour you may fine tune the carbs to "finish the job".
Check the DJ site for recommended needle positions and jet sizes for an open airbox. With the jets currently installed you may need the airbox lid fully open or need a minor jetting adjustment. It could be one step in the needle position for example. Having that data is valuable.
greencow
Seems to be the case Koko, fixed the pick up wiring, reinstalled while I wait for the new unit to arrive and put about 200-300 miles on the bike.  New plugs went in and so far they look a nice tan/gray on both cylinders.  Power deliver feels much smoother than before as well, although I guess that's to be expected considering the one cylinder was playing hooky with the pick up.  Hopefully I can finally rest and enjoy the damned thing after chasing my tail for the last couple of years.
The needle position should be checked against DJ'S recommended setting for an open airbox. It may well be correct, but it's worth checking on their site. The pilot and main jets appear reasonable (40 &140). Glad you found the ignition issue.
