April 27, 2024, 08:34:40 AM
A mountainbike racers quarantine m900s rebuild thread. what could go wrong...
Topic: A mountainbike racers quarantine m900s rebuild thread. what could go wrong... (Read 9506 times)
rsoffar
April 30, 2020, 08:22:33 AM »
hope this is the correct section for this type of thing.
Figured I could start documenting the slow process of someone figuring out how to rebuild their Moto.
Im no mechanic. Im a downhill racer. I wrench on bicycles, same thing right?
Short backstory. Ive had this 900 for 7 years give or take. A friend looped it out back then, we fixed it up but then with the mountainbike racing the Moto just sat and sat and sat and sat. Now, quarantine. Being that I can't get on the slopes seemed like a good time to take on a new project to take all my money.
Bought a Haynes manual, a Ducati manual and went to work.
there's no timeline for this. who knows. forever.
did I mention it was outside all those years? covered for the most part but still. a lot of snow and summers and everything in-between. Based off the amount of rat shit and bones there were some things living in there. Also might notice the yellow writing on the tank. Been impounded for parking on the sidewalk once (its usually inside the gated area but have to move it when they redid the brick on my building haha)
to note: this bike would start and run when I started disassembling. I just figured if I was gonna go in and after sitting for so long Id go all the way into the case and do some engine refinishing.
IMG_7221 copy
by
rsoffar
, on Flickr
Last Edit: April 30, 2020, 10:00:53 AM by rsoffar
'00 M900s
rsoffar
Re: A mountainbike racers quarantine m900s rebuild thread. what could go wrong...
April 30, 2020, 08:24:30 AM »
I'm pretty into this currently. Ill be uploading some pictures I've taken along the way so far and do a better job from here.
'00 M900s
rsoffar
April 30, 2020, 08:31:33 AM »
tear down.
Id say it went ok. The bike was gross. Like I said, things were living in there.
things had been eating on some of the plastic bits here and there as well. Looks like it mostly left the wires themselves alone but who knows.
IMG_7225 copy
by
rsoffar
, on Flickr
did the tear down outside out front
IMG_7226
by
rsoffar
, on Flickr
I only have these two stands. Made some little legs for the engine and can see had to get a little creative for holding the bike staple with some strap to the fences around me with nothing overhead.
IMG_7410
by
rsoffar
, on Flickr
IMG_7413
by
rsoffar
, on Flickr
then the fun part. we moved it all inside my apt
IMG_7576
by
rsoffar
, on Flickr
Last Edit: April 30, 2020, 10:03:05 AM by rsoffar
'00 M900s
greenohawk69
April 30, 2020, 09:32:17 AM »
Can't see any pictures.
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty: Soap, Ballot, Jury and Ammo. Please use in this order. -- Ed Howdershelt
rsoffar
April 30, 2020, 09:38:19 AM »
per standard I got 3 of these 4 nuts off and the 4th one was being a punk and rounded off. After a little more freeze off and some vice grips was able to make progress on it
IMG_7631
by
rsoffar
, on Flickr
IMG_7650
by
rsoffar
, on Flickr
pulling the heads was fun. Vertical heads came off easy breezy. the two nuts down behind the oil cooler for the horizontal one though.... yeeeeesh.
IMG_7656
by
rsoffar
, on Flickr
IMG_7662
by
rsoffar
, on Flickr
IMG_7663
by
rsoffar
, on Flickr
one of the lower studs on the horizontal head did come out from the wrong end even after so much freeze off spray. Guess Ill be replacing some cylinder head studs. Threads in the case look fine.
IMG_7660
by
rsoffar
, on Flickr
Last Edit: April 30, 2020, 10:05:52 AM by rsoffar
'00 M900s
rsoffar
April 30, 2020, 09:38:50 AM »
Quote from: greenohawk69 on April 30, 2020, 09:32:17 AM
oof thanks guess Ill have to figure out a different host
'00 M900s
greenohawk69
April 30, 2020, 10:00:31 AM »
Can see them now. You have your work cut out for you with bike being out in the conditions.
rsoffar
April 30, 2020, 10:09:53 AM »
cut up a socket to make a tool for the castle nuts on the pulley wheels
IMG_8395
by
rsoffar
, on Flickr
do they always have red locktite on the washers??
IMG_8401
by
rsoffar
, on Flickr
'00 M900s
rsoffar
April 30, 2020, 10:14:09 AM »
was excited to buy a new impact wrench to tackle the clutch
IMG_8213
by
rsoffar
, on Flickr
IMG_8071
by
rsoffar
, on Flickr
obviously the plates are in not the best shape. can I revive these somehow? or just have to bite the bullet and get a new set?
IMG_8220 copy
by
rsoffar
, on Flickr
IMG_8071
by
rsoffar
, on Flickr
the clutch pieces themselves cleaned up nicely
IMG_8217
by
rsoffar
, on Flickr
Last Edit: April 30, 2020, 10:19:54 AM by rsoffar
'00 M900s
rsoffar
April 30, 2020, 10:15:56 AM »
bicycles remember...
used an old bicycle crank puller to modify a little for a crankcase puller
IMG_7727
by
rsoffar
, on Flickr
'00 M900s
April 30, 2020, 10:20:12 AM »
Moved this build tread to General.
The red loctite was put on the nut, and got pushed down to the washer.
Blue loctite is more appropriate.
Inspect that harness in excruciating detail to make sure no rodents have compromised it.
That is a top-shelf slipper clutch.
Inspect that spider spring for cracks.
rsoffar
April 30, 2020, 10:22:23 AM »
piston heads came off, cleaned them up with a steam cleaner
IMG_8156
by
rsoffar
, on Flickr
IMG_8169
by
rsoffar
, on Flickr
'00 M900s
rsoffar
April 30, 2020, 10:26:36 AM »
Quote from: Speeddog on April 30, 2020, 10:20:12 AM
thanks. Ive actually been crawling the forum for wiring harness threads. Im already this far outside of my comfort zone why not right
'00 M900s
rsoffar
April 30, 2020, 10:30:08 AM »
I will admit. Im currently stuck on the primary drive gear. Internet research tells me its a real PIA. Borrowing a hydraulic gear puller to see if I can use that and some heat to do the trick at home. But from reading it sounds like I might shouldn't get my hopes up without the Ducati tool for it so I might end up taking a trip with the case to my local dealer for a little help here.
this was a lot all at once but Ive been working on it for a couple weeks now ha. Don't expect this to be a fast one as I order things I need as I go so sometimes were waiting on the mail.
Last Edit: April 30, 2020, 10:31:48 AM by rsoffar
'00 M900s
rsoffar
Reply #14 on:
April 30, 2020, 01:00:06 PM »
this slipper actually came from someone on this board back when the bike was crashed and had the original clutch badly damaged
'00 M900s
