April 26, 2024, 05:51:29 AM
another Ducati 1000 build....
10
11
12
Topic: another Ducati 1000 build.... (Read 42653 times)
buzzer
Re: another Ducati 1000 build....
Reply #150 on:
December 12, 2021, 05:55:20 AM »
Quote from: greenmonster on December 06, 2021, 08:55:21 AM
Perfect, thinking of an EV myself in near future.
Full Monty resto, including clutch, driveline and forks or what?
I wont do a restoration... just use it as a basis for a custom bike... already ordered the tank and carbs!
I am So SO annoyed with myself… the tank has taken days to get to the right shape… I etch primed it… prefect… 2K primer… perfect… just needed flatting before the base coat. Unfortunately I went through to the bare metal on an edge… Not wanting to have to fill the gun with 2K again I used some 1K primer… As the base coat dried… the 1K primer reacted… lesson learned!
buzzer
Reply #151 on:
December 16, 2021, 06:59:45 AM »
Well the tank is finally finished, bar for a mop and polish. It took a lot of time to rectify the paint reaction... I had to sand back to bare metal, and re primer the lot... I then put the tank above the radiator in the small bathroom and left the radiator on for 2 days to fully harden ...I had complaints about the smell of paint!!!
S2R 800 '07
Reply #152 on:
December 16, 2021, 07:32:37 AM »
Tell the complaint'er that it's free anti bug treatment
buzzer
Reply #153 on:
December 18, 2021, 08:01:04 AM »
Quote from: stopintime on December 16, 2021, 07:32:37 AM
you come and tell her... I am not that brave, and in need of brownie points!
My build is coming to an end... here is how it looks with clothes on....
Reply #154 on:
December 18, 2021, 08:46:21 AM »
Too pretty to go on dirt.
S2R 800 '07
Reply #155 on:
December 18, 2021, 10:33:58 AM »
Quote from: buzzer on December 18, 2021, 08:01:04 AM
BROWNIES
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
Reply #156 on:
December 19, 2021, 12:36:31 AM »
Awesome - a much overused word. But I am in awe of the range and depth of your skills
Looking forward to seeing your Guzzi build (while I too play over winter with my own much more modest Guzzi project).
Ducati
1100S
Monster
Ducati
1260ST
Multistrada
Moto Guzzi
Griso
1200SE
Previously:
Ducati
1200S
Multistrada
Ducati
Monster
696
Ducati
SD
900
Moto
Morini
Reply #157 on:
December 19, 2021, 06:20:30 AM »
Your work is impeccable, and I share ung's appreciation of your skillset.
You do need to find a paint supplier with more than one color, however. There are others you know. Sorry...had to say it.
pitbull
Reply #158 on:
December 23, 2021, 05:12:41 AM »
What an awesome and unique build. It's certainly better looking than any of the factory scrambler bikes.
buzzer
Reply #159 on:
December 24, 2021, 04:45:42 AM »
This will be my last post for a while... the Ducati build is almost at an end and before I start the next project I have a list of house DIY jobs to do :lol
this has been my 9th Ducati build / restoration so I fancy a change... the next bike will be a Guzzi 1100
For now, here is a short video that tells the story of the last build...
merry Christmas!
buzzer
Reply #160 on:
December 25, 2021, 03:07:01 AM »
Quote from: ducpainter on December 19, 2021, 06:20:30 AM
I know... I do seem to have a thing about orange!
buzzer
Reply #161 on:
January 27, 2022, 10:51:22 AM »
A couple of things were bugging me about this build… one was the inlet manifold where I had used the original rubber manifolds, they looked out of place, and gave to much movement on the carbs. I decided to re-make the manifolds. they are a bit difficult as the carbs are bigger than the port, so I had to expand some alloy tube a bit with a tapered mandrel.
The other thing was the foam filters… I really wanted bell mouths, but as the carbs were forward facing it was to risky to have big open, sucking carbs… So I decided to make some bell mouths with mesh… they came out well! I have also tidied up the under seat area.
Finally, I set the timing accurately it was out by 2 degrees cylinder to cylinder, probably do to me getting the positioning of the hall sensors slightly out. Its easy to correct for that in the ignitech software though.
A couple more videos... she says it sounds like a bag of spanners with the clutch out!
Reply #162 on:
January 28, 2022, 12:17:47 AM »
That under seat area is so tidy.
If I lived up the road I would have ordered manifolds from time to time instead of friggin' around with various rubber adaptors.
Really appreciate what you do with metal.
Reply #163 on:
January 28, 2022, 04:32:47 AM »
Fantastic work
greenmonster
Reply #164 on:
January 29, 2022, 06:08:25 AM »
Top work as always.
Any plans for a spin on the Dyno, engine sound really peppy w Ignitech?
M900 -97
MTS 1100s -07
10
11
12
