another Ducati 1000 build....
Started by buzzer, June 13, 2020, 07:12:58 AM
greenmonster
Very cool, buzzer! [clap]
So you are using Ignitech w the Hall sensor?
M900 -97
MTS 1100s  -07
buzzer
Quote from: greenmonster on September 05, 2020, 04:02:34 AM
yes, I got the idea off the fastbikegear website, and had some help of the Laverda guys...  Liam actually sells a kit to do it...
well its running really well now, and its got a very stable tickover...  dry clutch always sounds like a bag of spanners through!
here is a short video...
greenmonster
M900 -97
MTS 1100s  -07
buzzer
Now for the part I actually enjoy doing… the wiring! I am building this loom completely from scratch, save for things like the handlebar switches, although I am replacing the outer sheathing as it was tatty. I know this is something a lot of people struggle with but over the years I have developed a system… I start with a design in my head and I put it down in rough on my Ipad, using an Ipencil which I find brilliant. then I transfer it to visio, which I print out and add the colour of wires on as I go along. I don't try to it all on one diagram like in workshop manuals, but keep separate pages for different circuits like lights, indicators, ignition… I also create tables of key components where they have pin outs.
All this is put into the build folder which I always pass on when I sell the bikes.
I have a nice crimp tool which is normally sufficient, but if I am in any doubt I put a dab of solder on the joint. I also don't use pre insulate connectors, instead I put 20mm of heat shrink on which makes a nice joint, and the heat shrink also supports the joint. If you use the glue lined heat shrink, it also makes the joint waterproof. this is of course if I am not using super seal connectors which are not only excellent, but also cheap! and finally, I use the most useful little kit, which has tools for removing all types of pins from connectors!
greenmonster
M900 -97
MTS 1100s  -07
buzzer
Run out of a few wire connectors so moved onto the cam belt covers till they come… I made some of these a few years ago and they worked well… but this time I have made the holes oval and I think they look better. used a hole saw to cut the circles, and a saw in the dremel to cut the straight bits. just got to carbon dip them now and make the polycarbonate windows…
Also mounted the plate that holds the hall sensors
Oval definitely works well. Looks almost factory.
buzzer
Quote from: koko64 on September 21, 2020, 05:35:36 AM
Yes, I like the look of the oval windows
for some parts of the loom I have used this braided sheathing...  its a bit fiddly to do but the results are good.  I notice a lot of cars use this now on the loom.
Another job I have been meaning to get around to...  The FCR carbs need a one into two cable setup.  I was going to use a junction box off an old British bike, but all the ones I could see were either too short on the pull distance, or terrible quality, so I decided to make one.  I was going to make it out of aluminum but had difficulty getting nice threads, probably due to the grade of alloy bar I had.  so brass it is.  It also allowed me to put longer holes to retain the cables, all the ones I looked at only had short holes.
Quote from: buzzer on September 23, 2020, 09:40:44 AM
Looks strong and very tidy, that won't let you down! [thumbsup]
I'm using a Motion Pro 2 into 1 cable from Powerbarn USA. Although it works, it could use more cable adjustment and I dont know how long the plastic components will last. I have lubed them liberally hoping to extend their longevity.
buzzer
Quote from: howie on September 23, 2020, 10:40:29 PM
Gorgeous!
Thanks!  [thumbsup]
here is the plate to hold the ignition switch.  It didn't look right just flat, so I made a small press tool to add a raised ring where the switch goes.
I can see a little smudge on your glasses.
buzzer
buzzer
Finished the wiring apart from the horn as it didn't seem to like being bead blasted!
