Front end wiggle when downshifting
Started by Igor900, August 01, 2020, 05:51:00 PM
Buhgaboo
What are we talking about again?..lol
I think these posts are giving me headshake
DuciD03
To keep n topic were talking front end wiggle (that may, but probably not have to do with riding / engine break /de-cel )
my best guess would be with koko; front steering head proper torque adjustment; then the bearings in the steering head; as per you description at stop with some play (easy to check with one hand on front break and other on triple to frame connections then push back and forth; side to side); and head shaking at de-cel
then front wheel axel shaft proper torque adjustment, yoke bolts and end axel nut; then bearings …
if all that checks then same for rear wheel;
is the rear wheel bent?
then swing arm bearing adjustment;
chain & sprockets
main internal engine bearings ???
main engine mount through bolts???; check torque on those...eeeks,
... its a little disturbing ; need to pinpoint the issue.... but you know that that's why your posting.
.... all the world is yours.
S21FOLGORE
Quote from: Igor900 on August 09, 2020, 03:18:21 PM
<SNIP> knowing that I have to rebuild my front calipers (they're starting to stick). <SNIP>
When was the last time you cleaned the calipers?
Igor900
Quote from: S21FOLGORE on August 10, 2020, 02:08:35 AM
Doing that this weekend. I only have access to my boyfriend's garage on Sunday's (he manages a restoration garage for vintage volvo's). I'll be doing all of the adjustments and cleaning this Sunday and will be able to report back :)
Ddan
What about tire pressure?  I've found with Michelins 1 or 2 psi off can make a big difference in tracking through corners.  Even hard downshifting shouldn't on it's own put enough stress on anything to upset the front end, there might be something else going on.
Ducati Monster Forum at
www.ducatimonsterforum.org
On the street I found, both with the Pilots and Pures I needed to run higher pressure and felt the difference if they were a little low.
DuciD03
Igor; howz it going?
this was from a while ago;
(I hope you weren't wiggled of the bike …)
