3D printed headlight adapter
Started by greencow, August 19, 2020, 04:00:50 PM
ajw85
Quote from: greencow on September 15, 2020, 01:44:43 PM
Sure thing!
STL - http://www.filedropper.com/ducatiheadlightadapterringv02a
Gcode - http://www.filedropper.com/ce3producatiheadlightadapterringv02a  (if you just want to print it, those were the settings I used.)
It does sit the headlight pretty far out from the interior of the bucket, that was by design, so the secondary ring could have the space needed to capture the LED housing, and allow the spring clips to have enough tension still.  It might work as-is, with the spring clips bent inwards, but I haven't tested it that way.
Do you happen to have the STL for the secondary ring that goes on the back?
greencow
Hey, sorry man, I didn't see this until now.  If you still need it, it's here.  http://www.filedropper.com/ducatiheadlightadapterringclampv02a
greencow
Old links have long since died for the 3D file, put the current design up on thingiverse
https://www.thingiverse.com/thing:6279797
Heath
2007 Ducati Monster S4RT
