Monsterlover rejoins the fold
Started by Monsterlover, August 20, 2020, 05:01:00 PM
More work today. Got the ground cable all done and installed it along with the starter cable.
https://flic.kr/p/2kiSN1M
https://flic.kr/p/2kiSgLc
I also swapped out the right side engine cover for a machined out one I inherited years ago. I had it saved for just such an occasion.
I'm glad I did this as it gave me the chance to find out that the OEM clutch was slagged. The stack height was short some 1.5mm.
Luckily the spare engine that came with the bike had an aftermarket aluminum (Barnett?) clutch that I was able to harvest.
https://flic.kr/p/2kiNuF5
Very clean in there [thumbsup]
https://flic.kr/p/2kiSNF9
https://flic.kr/p/2kiNv5r
Wrong color on the side cover and you stuck with the steel basket?!?   [Dolph]
Quote from: Duck-Stew on December 20, 2020, 08:29:00 PM
Yeah I'm aware of the color change. It's not bothering me yet.
Fun fact, the two covers are different where the oil pressure sender screws in. On the original cover there is a "washer" surrounding the tapped hole that's part of the casting. The sender threads in and seals on it.
On the cover I installed there is the opposite. That area is actually counter bored and would not seal on the sender this bike had. Luck was on my side again and I was able to find a copper seal washer in my collection. I *think* it will seal up ok.
As for the basket, I'm working with parts already on hand. Oem in this case.
Though, I did have thoughts of taking the basket to the shop to add some holes in it to lighten it up.
Quote from: howie on December 20, 2020, 09:22:43 PM
Lookin good Kevin [thumbsup]
[thumbsup]
Satin black VHT on the clutch cover I reckon. [thumbsup]
Quote from: koko64 on December 21, 2020, 04:13:44 AM
I probably should just to make it look better. That cover has seen some shit.
Some early Superlights had those vented alloy covers. Others were carbon, but some of 851/888 SP models had those vented alloy covers too.  [thumbsup]
Quote from: koko64 on December 21, 2020, 04:13:52 PM
So it's factory?  But not for the ssfe it sounds like. It's not carbon. Definitely aluminum or steel but I think aluminum.
Early Corse style and later copied by aftermarket.
Covers on the supermono were vented as such, magnesium and a funky green color...
Mine isn't green. I'd be surprised if it was mag. Though, in not sure how to tell mag from aluminum.
Spent the end of the afternoon making some titanium washers to replace some missing ones.
https://flic.kr/p/2kjTcby
The two in the front haven't been deburred yet.
Kopfjäger
Kopfjäger
“Hello All, I replied to another post in another section and it reminded me of this bit of information. One of the other fellows posted a method for checking for magnesium, he said to file shavings from the part, put them into a pile and apply an oxy-acetylene flame to them, if they sparked and burned the material was likely magnesium. The method that I typically use requires silver nitrate, you apply a drop of this solution to the part to be tested, if the droplet turns the material black it is likely magnesium, if the droplet stays clear it is probably aluminum. One variation to this would be the possibility that the material is pot metal, it can also turn black when silver nitrate is applied, the pot metal part would be considerably heavier than the magnesium piece and will help to differentiate between pot metal and magnesium.”
Quote from: kopfjäger on December 23, 2020, 05:36:10 PM
Looks like I'll have to do some investigating tomorrow with a file and a lighter.  My money's on aluminum.
I quoted a job out of mag once. Had to include the cost of a class D fire extinguisher in the quote. Spent a lot of time on the phone with my insurance carrier finding out how long it takes to get paid after I torched a $125k mill and how long until I could replace it.
Didn't get the job.
Kopfjäger
