How to tell if a carb has been upgraded?
Started by brecchi, November 10, 2020, 07:07:48 PM
One off each carb vent pipe then to the hrs pod. The central T fitting has a breather pipe to the Lys pod.  The pods provide still air, however, there are kits to eliminate these like the TPO kit. I run the hoses up into an area that is protected from turbulence up under the rear of the airbox toward the battery.
brecchi
Thanks, I'll get things attached and post up a pic.
brecchi
Air breather hoses for the carb pistons. Baffle canisters more than filters in my opinion. The hoses go to the still air pods, but can be routed out of the air stream and cross winds.
brecchi
Sorry to just disappear for a while - I'm actually having a bit of trouble finding replacement hoses, I just need to look a bit harder.  I've only manage to source some clear hose.  I've got the carbs back together and will try to reassemble as best as I can.  I'll post an update when I get it back together.
TPO and Corse Dynamics had hose kits that deleted the pods. Auto store vacuum hose should work if you can get the correct size.
brecchi
Been put off by the freezing cold and in the process of moving.  I'm going to take a look into the TPS or Corse kits,  the correct vacuum hose has been hard to locate.  I keep messing up trying to reinstall, but I'll report back when I actually get something done!
