Monster will not start, UNLESS ....
Started by lanciahf, July 16, 2021, 05:28:03 PM
If you like to fiddle with small things, the kill switch can be disassembled and cleaned out.  Also look in the wiring connector from that switch to the harness.  I've seen corrosion there.
