Dirty clutch fluid
Started by greenmonster, September 25, 2021, 03:24:57 AM
Quote from: howie on September 29, 2021, 06:06:59 AM
Just change the fluid once a year and don't worry about the color.
This.
A good quality DOT4 - I like to use Motul 660, I'm sure there's others equally good.
MonsterHPD
I think one it turns black the only way to reverse the situation is disassemble and clean everything.  Just change the fluid once a year and don't worry about the color.
[thumbsup]
All my ducs (not that many, but anyway ....) have been like that. In the begining, I worried about it and changed the fluid, but with age-induced laziness setting in, fluid changes started happening only when made necessary by other causes. So far, I've never noticed a difference this way or that.
Infrequently, if not renewed as per above, I do pump thru some fluid and top up the reservoir, but that's it.
May not be the correct way, but it has worked so far  [coffee]
Monster 900-2002 (sold, alive and well in the UK), 749R / 1100 HYM combo for track days, wifes / my Monster Dark 800-2003 (not entirely "Dark" anymore and a personal favourite) , 50% of 900SSie -2000 track bike for rainy days-now with tuned ST2 motor and Microtec ECU. Also parked due to having been T-boned on track.
d3vi@nt
Quote from: ducpainter on September 28, 2021, 02:09:12 PM
That rubber bellows was just there to keep out the grime. The seal is inboard of that. I think it's just heat that does it.
The open unit allows for a lot more ingress, particularly if/when the bellows fails. Which would accelerate wear on the inboard seals. The slightly later units did away with the bellows and instead sealed up against the case. At least in my case, the closed unit cleared up my issues with dark fluid. Although, at 20+ years, I suppose all seals and OE rubber lines could be suspect for contributing to suspended particles.
'13 MTS GT
'99 ST2
'07 M695 - Sold
greenmonster
Not worried about colour, it`s that the the function gets worse.
Season almost over, will try other fluid next year.
What makes DOT 5.1 a better candidate?
M900 -97
MTS 1100s  -07
Higher wet and dry boiling points.
