December 21, 2024, 07:46:48 PM *
Pages: 1 [2]   Go Down
Author Topic: Electrical Troubleshooting help  (Read 4947 times)
Barney
when in doubt, pin it
« Reply #15 on: July 12, 2022, 04:59:01 AM »
You can do it without the tool, but you may damage something.  A cheap steering wheel puller with the correct bolts will do the job.  Your gasket is Threebond 1215 or similar.
You should have checked stator output before ordering parts.
Thanks for the tips!
I figured I'd roll the dice since the rectifier seems like a descent upgrade - I like the Li battery, the bike starts way better with it than it did with the AGM batteries I've had in it before.  I would've had to pull the bike apart to this point to get to the stator connection anyway, and the rectifier wasn't particularly expensive either so all I really lost is a little time.  I ordered the new battery as well.  Hopefully good for another 20k miles at least  waytogo
regarding the gasket - I found this on the motowheels site: https://motowheels.com/i-8184836-exactfit-alternator-cover-gasket.html - I've never used liquid gasket before, is there an advantage to it over something like that?
12 M1100EVO
09 KTM 200XC - sold. I cried.
70 Honda 450 Scrambler
« Reply #16 on: July 12, 2022, 08:16:58 AM »
I'm not sure about your Evo, but on the older bikes you would need to shim the sensor to make up for the thickness of the gasket.  Not a big deal.
« Reply #17 on: July 12, 2022, 10:43:28 AM »
I would use threebond with that model and use an Exactfit gasket on the early models.
Barney
« Reply #18 on: July 13, 2022, 04:47:05 AM »
thanks for the tip my man.
12 M1100EVO
Qomomoko
Return of the Yoga
« Reply #19 on: July 16, 2022, 04:27:01 AM »
When you charged the shorai, it is a good idea to check the individual cells.
You can do that with a multimeter and the different pins of the pigtail will be for each cell.
Off the top of my head minimum is 3.3 V for each cell. They have a troubleshooting guide and such.
the cells can be "super balanced" by charging , then charging again 2 more times back to back.
I would bet and hope it is just the voltage regulator and hopefully nothing else got messed up.
Could not find the individual cell info.. but here are some links
https://shoraipower.com/charging
https://shoraipower.com/lfxcheck
https://shoraipower.com/battery-specifications
Qomomoko
Return of the Yoga
« Reply #20 on: July 16, 2022, 05:05:44 AM »
Links of documents I found when my battery was acting up.
« Reply #21 on: July 16, 2022, 12:12:11 PM »
 waytogo
Barney
« Reply #22 on: July 18, 2022, 05:09:18 AM »
That's a top tip! Unfortunately I pulled the regulator out and replaced it with the mosfet RR I got from Rick's and there was no change in the way the bike was acting.  I haven't worked up the courage to pull case apart yet, but I've got a new stator in my hands and will probably be tackling that job one night this week.
12 M1100EVO
Pages: 1 [2]   Go Up
