My Ducati Won't turn on after 2 years of no activity
Started by Juanchojt, Yesterday at 07:06:34 AM
Juanchojt
#15
New update: The timing belt is intact and appears to be in good condition. Here is the video:
https://youtube.com/shorts/bVtvMjHaBsM?feature=share
The next step is to pull the cylinder head to see what's happening inside.
Regarding the spark plugs: I went to AutoZone, and they recommended the NGK DCPR8E based on my bike's year, make, and model. Previously, I was running Champion RA6HC. Do you think the cross-reference could be the issue? I suspect a piece of the broken plug may have dropped into the cylinder and caused the obstruction/damage.
Both plugs should be ok and the two sites I checked for "reach" (thread length it seems) list 19mm on both. So, probably correct plugs (even if that doesn't helpp you much...)
Those are the correct plugs. If they were too long, both plugs would have been damaged by contact with the piston...No?
Juanchojt
Fortunately, I only needed to replace the plug on the vertical cylinder, which was the only one showing impact damage. What internal issues would cause contact with the spark plug?
As mentioned 1;
belts - if it jumped a tooth or two a valve could suddenly be where it shouldn't
As mentioned 2;
a bent valve (seized?) might also suddenly be where it shouldn't
Which leads back to "As mentioned 3" - heads off and pray [thumbsup] , and please remember to take pictures and to share them.
I'm going to stand fast that you need to pull that head.
