January 01, 2025, 07:37:38 AM *
Pages: 1 [2]   Go Down
Author Topic: GPS Mount (pics pls)  (Read 6270 times)
duckb0y
2005 S2R Dark
« Reply #15 on: July 30, 2008, 03:01:34 PM »
I bought a mount on Amazon that came with the Ram cradle, a usb power cord, and some crappy linkage to hook it to the handlebars for about 30 bucks.  The crappy linkage broke, so I ponied up another 30 bucks for the genuine aluminum Ram linkage.  So far it seems a lot more sturdy.  I would go with the Ram mount kit.  I can post a picture of the Ram mount later if anyone wants.  Here is a link to my thread when I installed my gps.
RavnMonster
05 S4R
« Reply #16 on: July 30, 2008, 04:27:27 PM »
ok so with the RAM setup, what all do i need to buy? does the cradle come with the mount if I buy the mount or do I need to buy it separate?
I have a Garmin Street pilot C430
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
-- Eleanor Roosevelt, First Lady of the United States, 1945
DucME
« Reply #17 on: July 30, 2008, 04:49:13 PM »
The cable that I bought on Amazon (from one of the partner sites) was pretty long, and the guy at my local Duc shop suggested I hook into the brake light wiring, since it is easily accessed, and then I would only have a live connection when the ignition is on.  I ran the cable along the inside of the frame and attached it in a few places with zip ties, and I found a velcro piece at Lowes that I can use to hold the live end of the cable against the frame when I'm not using it.  When I am using it, the cable length is perfect and it has exactly enough play to turn my bars without any problems, but not hang loose at all.
Painted exhaust cans, painted belt and sprocket covers, shortened rear fender, cf side panels, hugger and heel guards,
removed evap cannister, Napoleon barend mirrors, black DML crankshaft cover - it's wicked dark
elevy18
« Reply #18 on: July 31, 2008, 05:44:25 AM »
Please excuse my ignorance, but why would anyone be adding a distraction to a bike?
scooby
<~ I am what I am ~>
« Reply #19 on: July 31, 2008, 06:41:07 AM »
  Huh?
Maybe so on long tours you can figure out where you are and where you are going... I use mine all the time as a "help, get me outta here!" tool; I explore a lot (I ride 3-4k a month) mostly by myself and when I get somewhere "out there" I use my GPS (which I keep in my tank bag) to get me "home"... An incredibly useful tool, IMO...
What would ScoobyDoo?
optiato
'07 695
« Reply #20 on: July 31, 2008, 11:50:11 AM »
Not the best picture and I don't have it all centered, but it was quick.  That's the RAM mount.
I actually have a small weatherproof power port (cigarette lighter adapter) mounted to the back of the windshield, now.
I have a few thousand miles with the GPS on, I usually take it off and just leave the ball mounted to the handlebars for my day-to-day riding.
DucME
« Reply #21 on: July 31, 2008, 12:20:11 PM »
It's not a distraction if you don't know where you're going.  I had a doctor's appointment yesterday in a town I'd never been to, and I got right there on time because of my GPS on my Monster.  Of course, on the way home the Garmin woman did a lot of recalculating because I took some scenic detours.
It's the same reason I use it in my car.  It's not that I like to look at pretty maps; I like to know where I'm going.
duckb0y
2005 S2R Dark
« Reply #22 on: August 01, 2008, 08:20:16 PM »
You need to pick out the parts separately.  If you go to http://www.ram-mount.com/products/motorcycles.htm you can get a good starting point.  From the looks of it you need to choose the cradle, the arm linkage, and the mount that goes on the handle bar.  I didn't see the C430 on the website, you may have to find out if there is another model that has the same body.
Chchadder
« Reply #23 on: August 01, 2008, 08:35:09 PM »
Check these guys out.  They had a really reasonable solution for a semi-obscure GPS I purchased a while back.  Just email them with your GPS info and how you want to mount it and they'll most likely be able to hook you up.
http://www.mountguys.com/SearchResults.asp?Cat=264&Click=2
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
woodyracing
« Reply #24 on: August 03, 2008, 08:37:57 AM »
I've got a RAM mount on mine, here is a pic:
bit more info on my install:
click
DucME
« Reply #25 on: August 03, 2008, 11:19:53 AM »
Try GPScity.com.  You can search the RAM mounts by GPS model and they have the pieces you'll need pre-packaged together.
DrNo08
« Reply #26 on: August 03, 2008, 12:00:30 PM »
click
Great tutorial.  thanks.  I'm located in Tupelo, by the way.  waytogo
herm
« Reply #27 on: August 03, 2008, 07:53:32 PM »
also check out the aqua box by Ram Mounts. it is a weatherproof box with a usable touch screen face. about 50.00, and will keep the electronics dry.
Pages: 1 [2]   Go Up
