One man's stand against the State of California
Started by MuscovyDuc, May 07, 2008, 04:42:09 PM
MuscovyDuc
QuoteLooks good!  Where did you put the coil?
QuoteIs there any trick to hiding the wiring after removing the side panels? Thanks.
I removed the Crankcase oil reservior several months ago and put a piece of sheet metal under the seat. I mounted the voltage regulator to the under side of the sheet metal (Thats why I still have the rear hugger on). So there is plenty of room on the top side for crap like wiring and the coil, I also have the resistors for my integrated turns mounted to the metal.
Cider
That's a good idea to get some fresh air across the regulator heat sink.
c_rex
I have mine suspended from heavy duty zip ties on the frame.  Someday I'll make a plate like that though!
duc996
       "Monster S4r"
       "KTM SMC 690"
