More wheel porn...
Started by Chchadder, August 01, 2008, 06:06:20 PM
DrNo08
Quote from: Chchadder on August 03, 2008, 11:47:25 AM
I used the bedliner stuff because of the texture, so I am a bit biased.  No clear coat on it at all and after 4 coats or so the level of texture actually seems a bit deeper.  I'd just do a flat black if you don't want the rough look.
Is yours holding up well?  I let mine sit for a while then decided to start over.  I just peeled it right off no problem at all.  Worried that it's not grabbing adaquaately.  Maybe it needs to set overnight.  Oh, and has yours faded at all?
Chchadder
I used it on my sprocket and timing belt covers in previous sessions about six months ago and they still look great.  The timing belt cover is starting to show a little wear but is still looking good.  No fading at all.  If yours peeled off I would say something in the prep didn't go right, though there's not really much to the prep either.  I let it sit for about ten minutes between coats and then let it sit overnight.  Came out fine each time.
09 Triumph Daytona 675 - Rocket -
07 695 Custom Dark - Sold -
This motorcycle is simply too goddamn fast to ride at speed in any kind of normal road traffic unless you're ready to go straight down the centerline with your nuts on fire and a silent scream in your throat. ~Hunter S. Thompson
