I ran out of gas and now m900 wont start...(carb)
Started by robartlum, August 10, 2008, 12:57:18 PM
Rameses
That's great man, glad to hear it was a simple solution.
And I'm envious of you for going to UGA.  There's some absolutely incredible umm, scenery there.   [evil]
Id keep an eye on your battery and carry that tender with you. Theres no reason a battery should fall flat on its face, other than its dying, or your bike isnt charging it. just a warning before you venture to far.
Quote from: He Man on August 13, 2008, 12:45:27 PM
+1...
I'd throw a voltmeter on the battery with the bike running about 3K
13.5-14.5 volts is what you should see.
Jobu
Quote from: ducpainter on August 13, 2008, 04:37:40 PM
+1...
+1
Do this to make sure your charging system is in good working order.  It is not uncommon for a motorcycle battery to go bad, especially after sitting for an extended period of time with no charge.  Buy a Battery Tender Jr. and keep it on that whenever possible.
9 times out of ten, maybe more, when a bike won't turn over it is the battery.  Batteries can be dead even when they show 12 v using a voltmeter.  That's why I suggested trying to jump it again.  Glad the problem was simple.  Wish my problem was.    :-\
And in case you dont heed our warnings. Learn how to bump start a motorcycle.
