high speed wobble
Started by MAXdB, August 12, 2008, 10:00:55 AM
hypurone
Quote from: ScottRNelson on August 12, 2008, 03:03:14 PM
The answer you should accept is "don't go that fast".
However, you might want to consider different tires.   When I had a Bridgestone BT-010 on the front of both of the Monsters that I owned, there was a definite high speed wobble there from about 80 mph on up.  Switching to a BT-020 made it completely disappear.  One Monster had a steering damper and the other didn't, and that didn't seem to make the slightest difference.
I happen to like both Pirelli and Avon sport touring tires for good, stable high speed behavior.
But you really should keep the speed down on public roads, especially if you ever ride in California where you get double the points for speeds over 99 mph.
Per the above quote, I have an S4RS and from day one it was a "nervous" bike. Even after fulling dialing in the suspension, raising the rear, damper (for those Oh Shit moments) air pressures adjusted to a multitude of settings yadda yadda yadda. Not until I replaced the Michelins did the bike stop being "nervous". I knew it was the tires after riding some rain grooves on the freeway and the make the beast with two backser felt like both tires went flat!!  [puke] I won't go into all the reasons I hate Michelins.
FWIW, my bike transformed with the Pirelli Diablo Corsa III's and now I'm back on my favs, the Metzeler Sportec M3's (the best!! IMHO. Steel belts baby!). Also, and this just may be a personal pref but after going to a 6.0 BST in the rear which necessitated a change to a 190, the bike is absolutely rock solid now. Nothing but shear 100% unadulterated hooliganism upsets this thing now! God I love a 190/6.0in rear!!  [clap]
JDS 07 S4Rs
Interesting thread. My S4RS WAS rock solid when I 1st bought it. I question why I even need ed a Damper !!!.
2 weeks ago I install one of my track take offs. A Metzeler. The guy who did it couldnt balance the tire cause he didnt have the spacers for a single sided rim.
Now the bike has a wiggle while accelerating from 100 to "Alot faster" mph.
The Pirelli I took off the back was squared. Even without a tread down the center it was solid. The Metz has a good center. I have a Pirelli on the front still.
I think my prob is tire combo,,,or tire balance. THat's likely the same problem that U R having. Probably tire balance !!!
Keep us posted when U find the fix.
2007 S4RS
2007 1098S Salvage Title (that's it. NO MORE BIKES)
02 GSXR 750 Trackbike - Ins Write/off
06 ZX636R Trackbike  - Ins Write-off (I couldnt help it, the price was right)
2003 BMW 1150R
2004 450 YZ
&,,, a few others :-)
DarkStaR
#17
Quote from: MAXdB on August 12, 2008, 11:21:07 AM
the sag is set up for my weight and I raised the ride height about an inch from lowest..
Quote from: speedevil on August 13, 2008, 05:23:38 AM
You indicate that you've raised the rear suspension height with the adjuster.  By doing that you've quickened the steering (decreased rake and trail) which will make it less stable.
Did the bike wobble before raising the rear suspension?  It might be worthwhile to lower it back to stock and see what happens.
+1 - Did it wobble before you raised the rear.  1" seems like a lot for a single adjustment?
hypurone
Quote from: DarkStaR on August 13, 2008, 07:56:09 AM
I raised mine 3/4 inch and it was a great improvement but the bike was still "nervous" to me.
Norm
I seriously doubt if the wobble, as described, has anything to do with the rear ride height.
mihama01
Its got to be wheel balance or an actual warped wheel or bearings.
Get the wheels balanced properly and check the bearings for any free play. Check the rims are true, ridden up any kerbs or landed heavily on the front?
Adjusting the suspension is may cause it to handle like crap, not wobble side to side.
At speed the bike can feel a little "light" and unstable on the front, but this is at 130+ mph.
If you are weaving at speed, then I suggest you relax your grip on the bars and try to tuck in behind the screen. Try to wear form fitting clothes/leathers that are not flapping in the wind.
As a start run the tyres at makers recomended pressures and make sure they have plenty of tread left. I have Pirelli Corsa IIs that suit the balance of street/circuit that i do.
I added 1 cm of ride height to the back (Measured from tip of rear mudguard) and it did improve stability. I am running standard springs and preload with a couple of clicks of additional damping front and rear. I am not that heavy.
And no don't slow down at all otherwise what is the point of an S4Rs?
Red S4Rs, Tokyo
MAXdB
Thanks to everyone for their input.. I've don't a couple things to see if I could relieve my bike of this wobble including checking the tire pressure, redo my suspension front and rear, as well as (try) to check my bearings..it does feel a little better with the tire pressure higher and suspension a bit softer. now when going straight, the bike seems to be alright but when I try to go through turns at high speeds, I still get a wobble..
also I was looking at my front tire and noticed that there were two sets of wheel weights on either side in different points of the wheel.. is that normal?
If the wheel was dynamically balanced yes.  Also many techs split the weight.  The only way to know is to remove the wheel and re balance.  You said your rear tire is almost gone.  If there is a wear pattern that is causing instability the only fix is a new tire.
