UPDATE...900ss Project (PIC HEAVY)
Started by vampireduc, August 12, 2008, 03:23:59 PM
Big Troubled Bear
Very good job so far [thumbsup]
Colouring looks awesome ;D
zarn02
neato. [thumbsup]
can't wait to see what she looks like when you're done.
roy-nexus-6
This is looking great.
Unfortunately, it ISN'T finished - and I'm not the most patient person in the world. I'm very keen to see how this looks finished.  [clap]
vampireduc
Paint is polyeurothaine with a  2 part epoxy clear.
Forks are painted...same, I'm hoping that teflon tape or something similar will aid in getting them into the triples with as few nicks as possible. (any adivce other than taking it easy, I'm open to)
And the ARMY blanket is mine!  Bought and paid for with 12 years so far...the final 8 shouldn't be to bad.   Maybe I'll get more than a blanket out of it.
Of the good in you I can speak but not of evil.  For what is evil but good tortured by its own hunger and thirst.
'97 M750...sold
'99 900ss...project, waiting on parts to finish the rebuild (sold)
'99 750ss...parts for the 900ss (sold)
'97 M750...again!
You'll scuff the hell out of the paint on the forks no matter how you do it.
the only way to color the fork tubes is to disassemble them and have the tubes hard anodized a different color.
but.....since you've already painted them...  Good luck.
DrDesmo
One thing to try re: the forks is taking a few clothespins, disassemble them so it's just the two pieces of wood, and wedge them into the triples to spread the openings up a bit.  Looking schweet  [thumbsup]
Adam
'95 916
'12 800XC
vampireduc
I have nothing but time....I'll try the clothes pins...I'll try taking my time, I have touch up paint to add the "hey look at my mess" idea.
Thanks guys.
Hey, thinking of which, I put my frame back on the engine yesterday, tightened everything up and there is vertical play in the mounting.  Is this normal?  I stopped there before I mounted the swingarm, rear shock, and triples.  Will that play go away when I get everything mounted and off the engine stand?
'97 M750...sold
'97 M750...again!
truckinduc
mine has a little play too. i think its normal untill you tighten it down. But then i drilled out my rear mount from 10mm to 12mm cause i kept snapping bolts. Less play now
vampireduc
my frame bolts are tightened down.  or are you talking all the suspension and etc.?
'97 M750...sold
'97 M750...again!
truckinduc
ok i didnt see that you had tightened everything down. Have you torqued everything to spec? Im talking frame only, no suspension hooked up. When i would get my bolts snug there would be a tad of verticle play. but it disappeared as i torqued, of course from the friction. I would check the holes for out of round. The monster rear motor mount bolts tended to loosen over time. That could cause the engine case or frame holes to become out of round. Good luck.
duc996
Hats off to you my friend! i envy people that are such mech inclined and does their own work!Good job!
       "Monster S4r"
       "KTM SMC 690"
greenohawk69
Nice job...can't wait to see the finished cycle.  I don't know why, but I get excited looking at these threads when somebody is taking things apart and putting them back together.   ;D
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty:  Soap, Ballot, Jury and Ammo.  Please use in this order.  -- Ed Howdershelt
sydmonster
Great project, best to you with it. I like the black/white paint scheme.  [thumbsup] - Chris
ps, I know what its like a DIY project on budget.
...Sydmonster - down under
Contact me about your mods and what Street Cred Points you can earn!
vampireduc
Need just a few more dollars...new tires...and being home to actually work on it.  Getting closer.
'97 M750...sold
'97 M750...again!
Outstanding work!!  Good on you for taking it on, and for your family for pitching in too!
Out of curiosity, where are you posted?  Let me know if you ever get assigned to the aviation regiment here at Wheeler (on Oahu).  We are always looking for another Ducati to go riding with.  ;)
