February 01, 2025, 11:01:10 AM
Please Help
OZ monsters
questions: removing stock grips / Rizoma installation & photoshop expert
Topic: questions: removing stock grips / Rizoma installation & photoshop expert (Read 3597 times)
DosVerde
has great respect for his
Re: questions: removing stock grips / Rizoma installation & photoshop expert
Reply #15 on:
August 13, 2008, 04:48:12 AM »
You have long slender fingers don't you Spider? Just leave the controls where they are, probably suit you better anyway, plus a gap isn't that bad
Just a thought
Betty
Reply #16 on:
August 13, 2008, 05:28:34 AM »
Will have to do something on the throttle side though as the grip and throttle control need to come together. The gaps are significant but probably prevented me from getting shorty levers.
q monster
Reply #17 on:
August 13, 2008, 07:25:29 AM »
i fitted my rizoma grips a few weeks ago - throttle side drilled a new hole - very hard to see the old one with all the other stuff there. only trick is to drill the right size so that the pin goes in easy but snug. on the clutch side easy to line up right at the end so no gap. fit should take you about 15 minutes.
old grips - i can't see myself using them again so i got out the knife
don't like the OEM levers though - too far away - thinking of getting Titax shorty levers in black
q monster
2008 S2R1000 changed - spark headers and tail cut done, rizoma grips indicator lights and clutch cover titax levers, DP ECU, open filter, ...... maybe stop then............. nah think i'll add rizoma rearsets and their conical handlebar is f..hot... and then i need to get rid of those mirrors....
DosVerde
Reply #18 on:
August 14, 2008, 01:41:19 AM »
Quote from: Betty on August 13, 2008, 05:28:34 AM
Yeah, I'm a goose, forgot about the throttle
Spider
Ozmonsters: degenerating nicely since 2008
I may be long, but I fold up nicely
Reply #19 on:
August 14, 2008, 02:44:56 AM »
put down the Stanley knife Brendan....let's think about things before we start slicing grips off all willy-nilly like, eh!
here's another question - do rizoma mirrors come with a protective surface that has to be removed over the mirror surface - or is that blue colour the tint of the glass>?
Thanks to Matty for putting up his hand with my photoshop request, Tool would turn over in his grave with all this support...I regular love-in!
DosVerde
Reply #20 on:
August 14, 2008, 03:54:02 AM »
Quote from: Spider on August 14, 2008, 02:44:56 AM
Like I always say,
If in doubt, knife it out
Actually I can answer the mirror question for you Spider. The mirror is tinted blue. Are mine the same? does it look ok?
roy-nexus-6
Re: questions: removing stock grips & photoshop expert
Reply #21 on:
August 14, 2008, 06:23:33 AM »
Quote from: Dockstrada on August 13, 2008, 01:14:14 AM
the easiest way I have found is to get your self a Phillips head screw driver ,a very narrow one cover it with WD40 slide it between the grip and the bar all the way the length of the grip being gentle rotate it like you are a screwing a screw adding some WD as it goes naturally around the bar. it will slip off in a jiffy
WD-40 comes with a very narrow plastic straw.. would that fit under the grip? You could then just squirt it in.
Spider
Reply #22 on:
August 14, 2008, 02:36:32 PM »
Quote from: DosVerde on August 14, 2008, 03:54:02 AM
It looks gay. I hopped off the bike and some old betty came up with a pale pink wash put through her perm (on her way to the bowls, Ita?) and said "nice mirrors sonny buy!".
Yours are the same!
Everytime I look in mine there is some handsome bastard there....I can't promise the same for you though
Betty
Reply #23 on:
August 14, 2008, 02:52:27 PM »
not
Oops, meant to say gaps are not significant .... perhaps not too signficant.
And yes the blue tint is permanent (although I don't think all the Rizoma mirrors have it) .... should have a cool, calming effect on you.
Jukie
I need a
Paradise
Reply #24 on:
August 16, 2008, 03:08:54 PM »
Quote from: Spider on August 13, 2008, 02:43:24 AM
grips are off - easy after Dock's advice....
get Jukie on here - I need some advice on the grip install! not you useless b@stards!
bring me the woman!
gotta love you spider, you know the women always do all the hard work. i will alway help a man in destressed.
Before Honda CB125N
Suzuki GS125
Now. Ducati 620ie
Lambretta Li150
Ducati S4RT
Spider
Reply #25 on:
August 16, 2008, 03:20:16 PM »
in a previous thread you had mentioned working on the bike (naked, daughter of a mechanic etc) and I admit when I was playing round with the grips and control bodies I though where is Jukie and her tool belt - I need a powerdrill (don't own one - not much use on the bicycles!).
I'm waiting until I install the new top clamp and Magura bars - then I'll drill (or more likely get Madalf too!) and put the new grips and barends on....but you were spot on...the mirrors have really altered the look of the bike (and I can see behind me now!)
Thanks
