Long-Term Storage; Anything I should know?
Started by johnster, August 13, 2008, 06:56:27 AM
Quote from: uclabiker06 on August 13, 2008, 11:52:43 PM
Well, I heard your supposed to deflate them.
Some believe in deflating to half pressure if the tires are off the ground.  I think you will find differing opinions on this.
uclabiker06
Well I don't think they will necessarily dry rot.  But they definitely wont be track worthy; so I see your point.
QuoteSome believe in deflating to half pressure if the tires are off the ground.  I think you will find differing opinions on this.
I think when you say inflate them to max you mean only if they are on the ground in order to prevent a flat spot.  But ideally they should not be on the ground and the should be deflated to half pressure if they are not on the ground.
2006 S2R
2009 Smart
Yes, when on the ground.  I neither agree or disagree with deflating to half pressure when elevated.  IMO, I doubt it matters.
