February 02, 2025, 09:49:32 AM *
Pages: 1 ... 263 264 [265] 266 267 ... 284   Go Down
Author Topic: Weekly Sunday morning Jamba Juice ride  (Read 512328 times)
MadDuck
The anti-
« Reply #3960 on: February 02, 2016, 10:54:00 PM »
interesting that the bike in the picture has that GP exhaust but hasn't blocked off the SAS?  ? ?  Huh?
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #3961 on: March 20, 2016, 05:13:18 PM »
Solo ride this morning starting with the usual windward stuff, then to the N. Shore...Snake is finished except for the first three turns at the top, which have been dragged but not paved, and is no fun at all... Tongue
Life is tough, it's tougher if you're stupid...
Gettin' old ain't for wimps...
You only live once and I feel like I'm running out of time...
MadDuck
The anti-
« Reply #3962 on: March 21, 2016, 06:36:45 AM »
Let's see .......... The top three turns? ? ? That should only take them about another month to finish.
What are you doing this Thursday afternoon?
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #3963 on: March 21, 2016, 07:28:18 AM »
Nothing on my calendar, what's up?...
MadDuck
The anti-
« Reply #3964 on: March 21, 2016, 09:33:59 AM »
Got a dyno tune scheduled for the morning so I'm taking the day off. Might be open for an afternoon ride.  However, the weather forecast is looking none too good at the moment & I might have to reschedule everything.   Angry   Stay tuned.
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #3965 on: March 21, 2016, 10:28:41 AM »
Roger...who's doing the dyno tune?
« Last Edit: March 21, 2016, 10:37:43 AM by Speed 3 Pilot » Logged
MadDuck
The anti-
« Reply #3966 on: March 21, 2016, 12:54:20 PM »
Montgomery Motors.  RevTek wants $1,000.00 to do it.   Roll Eyes
MadDuck
The anti-
« Reply #3967 on: March 23, 2016, 09:52:35 AM »
So......... tomorrow might not be too bad after all ...........
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #3968 on: March 23, 2016, 06:25:04 PM »
Tomorrow not looking good for me, spring break childcare duties for the grandson...
MadDuck
The anti-
« Reply #3969 on: March 23, 2016, 09:53:34 PM »
It is what it is.
« Reply #3970 on: March 24, 2016, 01:48:01 PM »
How'd the dyno session go?
« Last Edit: March 24, 2016, 01:50:30 PM by DRKWNG » Logged
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #3971 on: March 24, 2016, 06:39:34 PM »
 popcorn
MadDuck
The anti-
« Reply #3972 on: March 25, 2016, 09:03:46 AM »
I took it in for a base run last Sat. That was done with just the factory Akra reflash, the SAS plates installed and the K&N airfilter put into the stock airbox. Stilling running both oxygen sensors.  We got 163 HP at the rear wheel and 96.5 lbs torque.  Fueling was at 13.5:1 up to about 3500 rpm and then richened up to 13:1 all the way up to redline. Bryce, the tuner, said it doesn't get much better. Also said that the bike was making more power than some RC8R's they had on the dyno.
I installed the PC5 on Sunday, took out the oxygen sensors & installed the O2 sensor bypass dongles. Removed the evaporative cannister, pump & hoses & installed the MotoHooligan airbox with twin 80mm stacks.  Actually no real huge intake noise increase. You can hear a change but not anything like sucking babies off the sidewalk. The PC5 comes loaded with a map for a stock set up bike (?) so I copied that and then made a "zero" map where there is no additional fueling or reduction of fueling. Sort of like a clean chalkboard. I was also able to download a few other maps from Rottweiler that had been custom made to work on the 1290 with the Akra system, the Akra reflash, and the Rottwieler airbox system ( similar to the MotoHooligan ). Loaded those maps onto a thumb drive and off I went yesterday.
So with the Zero map in and running what I noticed immediately was how nice the low rpm's were. I will chalk that up to having removed the O2 sensors & putting those bypass dongles in. Very noticeably smoother and almost no herky-jerky big twin feel between 3k & 4k.  It doesn't much like being under 3k no matter what anyway.
I told them to do a base run with the Zero map and then to run the custom map I had just so we could look to see where we were. The custom map chopped the low to middle range fueling by around 3 to 4% and added up to 10-13% more gas up high. The plan was to see how all that worked and then to build a custom map from there to make improvements.
The Zero map was spot on. Almost a straight line 13:1 all the way across the rev range. 165.5HP at the rear wheel and 99.1 lbs torque.  The custom map dropped the fueling down to around 12.5:1 ( a bit richer ) but absolutely no increase in HP or torque. Bryce said you couldn't draw better lines so we didn't go for any custom map on our side. He even said that when running the 12.5:1 map you could feel the engine lose a bit a crispness and that it wasn't running as good as it was with the Zero map.
So, in the end, the biggest change was putting the Akra full system on with the fueling/ignition reflash from the factory. Probably the next most influential change was to lose the O2 sensors and put those bypass dongles in. The MotoHooligan was icing on the cake.  After all of that it turns out that the PC5 isn't really needed on my bike but it is still in there at this time.
« Last Edit: March 26, 2016, 04:15:06 PM by MadDuck » Logged
MadDuck
The anti-
« Reply #3973 on: March 25, 2016, 09:18:19 AM »
The worst part was that I got there at opening time, 9am, but ended up waiting until past lunch before they started on the tuning.  There was a problem bike left over from the day before that had to be sorted before Bryce could get to my bike.  Sounds vaguely familiar so I'm not immune to those things happening either.   Roll Eyes Roll Eyes Grin
Speed 3 Pilot
Geezer
2014 Speed Triple R
« Reply #3974 on: March 25, 2016, 10:47:12 AM »
99.4 lbs torque.
Crazy!... Shocked
Pages: 1 ... 263 264 [265] 266 267 ... 284   Go Up
