Valve Guides - How do you know they are faulty?
Started by CairnsDuc, August 20, 2008, 05:21:23 AM
Quote from: uclabiker06 on August 21, 2008, 01:45:06 PM
So is it possible that that's just how the 1000 guides were supposed to be? I wonder if any of the dealerships took advantage of such a subtle spec this by getting new valve guides for bikes under warranty even though the looseness would not have caused problems;  since Ducati pays them for warranty work.
No because after a while it gets worst and worst. I have the same symptoms of gus duc, Mech says its the valve guides when he was doing valves, heads got sent out today and they are very optimistic that they are getting them back earlier next week. so ill tell you how it runs then.
uclabiker06
QuoteNo because after a while it gets worst and worst. I have the same symptoms of gus duc, Mech says its the valve guides when he was doing valves, heads got sent out today and they are very optimistic that they are getting them back earlier next week. so ill tell you how it runs then.
Please do.
2006 S2R
2009 Smart
DesmoTillDeath
He Man, Id be interested to see how much that valve job cost you, if you dont mind?
'01 900D: open airbox, K&N filter, termi slipon high mounts, Barnett lightweight clutch basket, 12VDC accessory port
'01 m900: Project; tail chop, raised seat pan, 999 tank, clipons, 900SS front upper half fairing, ST2 footpegs
'71 BSA B25T: Fully restored (custom). Clubman bars. POS
herm
12k on my bad valve guides....discovered after warranty. i have no noticeable issues, and some day i plan to do a big bore kit, so not worried at the moment.
Novelo
Quote from: DesmoTillDeath on April 24, 2013, 03:59:24 PM
Had both of mine done at separate times give or take some dollars about $350 with head off that was both guides, seats, and cutting valves.
