DIY Motorcycle Table
Started by Dragsterhund, August 20, 2008, 09:24:41 AM
http://www.afabonline.com/table_lift_plans.htm
I think the plans are $30.  Im guessing materials would be maybe $30 or so.  I figure you could build the table for less than $100 and it's a drive it on and lift it affair.
kenthecarp
Quote from: vampireduc on August 22, 2008, 06:47:25 PM
ken,
the Triangle braces that are supporting the bike.  Did you make those too?  Do you have any close-up pictures of them.
That is a great table.  I'm working off my own hand made stand right now.
The triangle braces are a set that uses a 1/2" drill rod, I normally slip it through the rear axle to clean/lube the chain.
When the rod is placed in the swing arm pivot the rear wheel can be removed, a small scissor jack and block of wood will lift the front wheel.
I'll take some more photos at lunch.
I'm trying to figure out how to share the table plans, I have the plans in a PDF and JPEG format, not sure where to put them?
kEN
erkishhorde
Quote from: kenthecarp on August 25, 2008, 07:40:54 AM
You'll probably have to upload them to something like fileshare.com or rapidshare.com and then link to them.
vampireduc
thank you ken.  That works for me.  Please send pictures if you have them, but the bracing idea will work for what I'm doing .
Tim
Of the good in you I can speak but not of evil.  For what is evil but good tortured by its own hunger and thirst.
'97 M750...sold
'99 900ss...project, waiting on parts to finish the rebuild (sold)
'99 750ss...parts for the 900ss (sold)
'97 M750...again!
kenthecarp
kenthecarp
Anyone interested in the full size image, send me a PM and I'll forward one.
(900 k.  6500x4000 pix)
kEN
Howley
Quote from: kenthecarp on August 26, 2008, 08:29:16 AM
kEN
That my friend, is genius.
DrDesmo
Can you send it my way?  ;D
Adam
'95 916
'12 800XC
Rob Hilding
Quote from: Monsterlover on August 23, 2008, 09:06:23 PM
That is a nice lift. Looks like it would work great!
I think you might be a bit low on the material cost estimate.
Priced any steel lately......... Probably $150-200 materials + the floor jack
Not being critical, cause I like the lift
At that rate the Harbor Freight one is prolly not a bad one to look at........
Don't know.
I have the jack already, and while you're probably right it would be more than $30, I don't think it would cost 150-200.  I can get a pretty good deal on steel locally.
vwboomer
you could get cut offs from a local shop and piece it together. Cheaper that way. Assuming you can weld anyway :)
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
faolan01
thanks for the plans!  [thumbsup] now I just need to find time to build it...
