Fuel Tank Nastiness
Started by Ronr, August 21, 2008, 03:02:38 PM
RichD
Quote from: Ronr on September 05, 2008, 03:42:35 PM
Sounds great!!  What do you have in mind?  :-*
I did a little test loop through southeast Lancaster, out to the airport and back.  I can't find anything missing yet, so that's a good sign.  It ran pretty good and the brakes stopped me okay.  The forks felt good.  I lowered the front end 1.0 mm when I installed the forks just to play with the handling, and that felt pretty good so far for a leisurely ride.
One thing that was weird.  I filled up the tank before I left (not completely but close) and rolled it into the driveway to start it.  After a few minutes, while I was getting my gear on, gas started pouring out the internal tank vent drain tube.  I opened the tank cap and it kept flowing.  It finally stopped for some reason.  Never had that happen with this bike, hope it doesn't become a habit.
Some bikes, (my SS is one of them) the vent tube runs through the tank.
If the hose splits, it'll drain the tank to thak level...
DFW-MFer!
Bonwilder
Ronr
Quote from: SUPER DUKE! on September 05, 2008, 04:06:48 PM
Maybe my tank repair kit dissolved a beneficial bit of tubing.  I need to get me a small mirror on a stick so I can peer inside the tank.  Should be fixable if that's all it is.
