January 06, 2025, 01:41:12 AM *
Author Topic: CycleCat Clip-ons w/Speedymoto Top Triple Clamp  (Read 3822 times)
DucHead
No garage queens
« on: August 27, 2008, 06:38:53 AM »
I have the CycleCat DBR-43 setup with the lower clip-on adapters:
If I replace my CycleCat top triple with the Speedymoto unit, will the CycleCat clip-ons work?  Does anyone have this setup who's willing to share/post a pic?  I'd like to see the height of the clip-ons.
Thanks,
  Dave
« Last Edit: August 27, 2008, 06:42:47 AM by pompetta » Logged
MonsterMan1036
« Reply #1 on: August 27, 2008, 07:12:55 AM »
I had the same setup as you but with the lower rise bars. Then I had Alex Ortner make a custom top triple and I had to put the CC under the triple.
You'll have to do the same if you go with the Speedymoto triple.
Alex Ortner 1036CS
1036 Foggy Monster (sold)
Commonwealth 848 track bike
1199 Tri
DucHead
No garage queens
« Reply #2 on: August 27, 2008, 10:28:45 AM »
...You'll have to do the same if you go with the Speedymoto triple.
If by "..do the same..." you mean go under the triple, then that's the plan.
Are any changes in cable length(s) necessary?
MonsterMan1036
« Reply #3 on: August 29, 2008, 11:46:13 AM »
Yes, that is what I meant. It looks like you should be fine with you brake line lengths.
Alex Ortner 1036CS
1199 Tri
Statler
« Reply #4 on: August 29, 2008, 11:53:31 AM »
I have cyclecats under a speedymoto triple.  stock lengths work fine.   I'll find pictures if you'd like.
