February 01, 2025, 11:03:45 AM *
Author Topic: Riding home tonight - now only have two gears????  (Read 1403 times)
BribieDuc
2002 Monster 620 ieS-Yellow/1966 Ducati Monza-red
« on: August 28, 2008, 12:11:49 AM »
Riding home from work tonight and about a km from home, couldn't change down into second or first.  Kept going and on stopping can now only select fourth or fifth.  The gearlever doesn't seen to return to a mid position, just drops down.  What's up...any ideas??
2002 620ie, I've put about 80k on her, runs daily 150km...no indications of impending doom at all.   Huh?
John
Super T.I.B
« Reply #1 on: August 28, 2008, 12:24:19 AM »
I have no idea but post this up in Tech as well and see what you get.
ace70
« Reply #2 on: August 28, 2008, 01:21:23 AM »
Can you engage the other gears by lifting up the gear lever manually to the centre position then selecting? if so,
A broken $7 return spring on the selector arm Angry
Need to access it through the LHS of the engine, behind the alternator cover.
Not a huge job, need to take some bits off the end of the crank to access it.
Half a day job, if not experienced.
Cheers
Richie
« Last Edit: August 28, 2008, 01:23:44 AM by ace70 » Logged
1995 M900 il Mostro
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #3 on: August 28, 2008, 01:34:56 AM »
yep, richie is right, that's all it will be. it's a pain in the arse to change though.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
BribieDuc
« Reply #4 on: August 28, 2008, 01:37:20 AM »
Thanks for the advice so far - have posted on Tech.
Sadly, can't seem to select anything but 4th and fifth.  No further motion downwards.
DUCMONROB
Geez its getting hot holding my
Nothing like the sound of a Ducati!
« Reply #5 on: August 28, 2008, 03:01:35 AM »
The broken tail of the spring may have fallen to a place to cause the problem.
Rob
M1000SDS, ZZR1200, GPZ900R.
Gone:
900 Monster Special
S2R1000
998 Matrix
BribieDuc
« Reply #6 on: August 28, 2008, 01:41:15 PM »
You're spot on the money.
This morning for some reason, it does change down into the lower gears once you 'manually' lift the gear lever up a little.  Rode into the workshop really early (given the advice about it being tricky to do for the inexperienced) and bingo....one spring required, pick up this afternoon.  Smiley
Thanks everyone ... appreciate all the unput.
Weekend task... take the Monza for a run.
Regards,  John
