Removed clutch cover, now smelling oil
Started by CDawg, May 08, 2008, 01:33:10 PM
CDawg
Hiya!
Got a dumb question.  I recently removed my clutch cover in anticipation of going vented and bling pressure plate.  Something when I stop at a red light, I'll detect a faint synthetic oil smell.  There seems to be no leakage from the oil filter and nut or the dry clutch.  Is just the oil lubricating the other side of the dry clutch and normal?
Thansk!
You may have a leak or weep from another area, and the now-open spinning clutch is pumping air forward to your nose.
Are you running the OEM oil breather tank, or perhaps a K&N on top of the breather valve?
CDawg
Oil breather is stock. Good point on the movement of air. I'll keep an eye out.
Juan
Just remember to put back the bolts that were holding the clutch cover, some people don't put them back..!
CDawg
Quote from: Juan on May 08, 2008, 05:40:52 PM
Really?!?!
Well, That's my problem!  duh!
clubhousemotorsports
You are far  from the first person to do that. It was good that you were tuned in enough to catch it at this point. now just keep an eye for oil leaks at the clutch housing to case . The sealer  the factory uses is pretty good but if the bond broke it may weep.
CDawg
#7
ducvet,
Will do!  Thanks for the heads-up! [fingers crossed] hope I didn't do any damage to the bike... :-[
CDawg
