January 06, 2025, 01:33:18 AM *
Author Topic: Stock ECU adjustments  (Read 2203 times)
Bbrent
'08 S4RS Tricolore
« on: September 03, 2008, 11:49:21 AM »
I understand that these bikes run pretty lean from the factory. I did a partial chop on my airbox and I'm wondering if there is anyway the dealership can make any adjustments to the stock ECU. Any feedback is appreciated.
Brian
hypurone
« Reply #1 on: September 03, 2008, 11:57:43 AM »
Very little. Some CO % but primarily idle speed, TPS etc.
CairnsDuc
« Reply #2 on: September 03, 2008, 12:47:06 PM »
Well out of interest, I have just had the Termi kit fitted by my dealer (ECU, Pipes and filter with open airbox)
Now when they installed the kit it was found that the DP ECU was faulty (Could not detect an air pressure sensor)
They installed the Termi cans and the air box/filter, the guys played around with the DDS (Ducati Diagnostic system?) and played around with the fuel settings to get the bike running fine with the OEM ECU.
It's not perfect, it uses a bit more fuel than it normally would and it pops a little on deceleration.
But the guys were at the limit of adjustment of the OEM ECU, they wanted to make it a little rich rather than risk the system leaning out.
The OEM ECU can't really take advantage of the difference the new Airbox and pipes give, but with the DP ECU arriving early next week it will be interesting to see what difference is made to the bike.
« Last Edit: September 03, 2008, 12:48:41 PM by CairnsDuc » Logged
uclabiker06
"The time you enjoy wasting isn't wasted"
« Reply #3 on: September 03, 2008, 04:12:25 PM »
The amount of adjustment of the OEM ECU is very limited specially if you have an 02 sensor, but whether or not you have an 02 sensor the changes that need to be made if you touched the air box can't be made through adjusting the OEM ECU.  If you touched your air box the responsible thing to do would be to get a PCIII (with a custom map) or something similar.
2006 S2R
2009 Smart
Bbrent
'08 S4RS Tricolore
« Reply #4 on: September 03, 2008, 06:19:34 PM »
And that would require a DP ECU right?
« Reply #5 on: September 03, 2008, 07:01:46 PM »
depends on what bike. People have had success with a PC III on stock ecu on 06 S2R1000s (o2 enabled) so i am going to try it. 07+ bikes have some new function in the ECU that will turn on the check engine light when hte o2 is removed, which is the only way to get the PC to work.
hypurone
« Reply #6 on: September 04, 2008, 05:14:29 AM »
Right now? In a word, yes. There are rumors swirling that PC has come up with or is nearing completion of a unit that will work with the stock ECU & O2 on E3 bikes. But I gotta tell ya, it ain't gonna be anywhere near the magic of a DP ECU. Add an earlier model PCIII on top of it and you've got some serious goodness. Ask me how I know...  [moto]
supertjeduc
« Reply #7 on: September 04, 2008, 10:48:53 AM »
My dealer (Biggelaar in the Netherlands) says on his site he can rewrite any Ducati ECU from 2003 and up
Maybe someone in the US can do the same (why not)
