Some sort of rubbing in my drive train
Started by Le Pirate, September 05, 2008, 02:43:07 PM
Le Pirate
I have a 2003 620 (DSS)
I adjusted my chain the other day due to it being really loose. Got it back into spec according to the sticker on the bike, torqued the axle back down to what it's supposed to be (per Haynes manual).
So take the bike out and at lower speeds, and while coasting you can here some sort of rubbing (sort of like when a bike chain hits a deraileur?). I think it's somewhere in the chain drive, due to the fact that at higher speeds it's more often, and as the bike slows the noise happens less often. It happens whether you are coasting clutch in, or at a constant speed under power.
As you slow down (below 20mph) you can actually feel when it rubs as the chain comes around. I've taken off the sprocket cover, and the mudguard/chainguard and it still doing it...I can't see where it's hitting. I'm afraid it was the brake rotor, but the gaps in the noise make me think it must be the chain (if it was the brake rotor being warped it would be a more frequent noise, I believe).
Any help would be greatly, greatly, greatly appriciated!!!!!
erkishhorde
Quote from: Le Pirate on September 05, 2008, 02:43:07 PM
Did you inspect the chain for stiff links as well? You could have localized stretching in the chain so while you adjust the tightest spot to the allowances the loose spots drag on the top of the chain guard that's on top of the swing arm. If it is this, you can't hear it at higher speeds because the chain is more taunt and therefor doesn't drag.
Le Pirate
Quote from: Speeddog on September 05, 2008, 02:58:39 PM
How many miles on that chain?
12k on the chain
Quote from: erkishhorde on September 05, 2008, 03:30:18 PM
this could be it. I kinda just had to eye ball it....I don't have a rear stand and I was working by myself, so I had to push the bike while watching over the side to find the right spot to adjust to
CairnsDuc
Is the axle aligned properly?
I adjusted my chain on an older bike and didn't align the axle correctly and the chain was not coming of the rear sprocket straight, destroyed a rear sprocket and chain in very short order doing that.
Le Pirate
Quote from: CairnsDuc on September 05, 2008, 06:11:06 PM
I measured 3 times after I adjusted. It's straight.
.....though now that it's been brought up, I'm going to have to check again. DAMN YOU, OCD  [bang]
erkishhorde
Where do you measure to tell that you're straight? I still haven't figured it out so I take the bike for a short ride and see if it's crabbing.
Le Pirate
Quote from: erkishhorde on September 06, 2008, 10:30:59 AM
I measured from the front where the swing arm is attatched and from the back...it was square all around.
Le Pirate
I made a short video of the chain while I was riding around the hood, to see if I could tell what is going wrong. Turns out my camera can't record sound  [bang] so you can't here when it's rubbing.
anyways, maybe it'll help find the problem. Yes...I was wearing shorts, driving down the street infront of my house.  [cheeky]
To check if your wheel is square in the swing arm, take a tape measure and measure the distance from the center of the swing arm pivot to the center of the axle on both sides.  The distance should be equal.  To check if your sprockets line up, use a straight edge from sprocket to sprocket.  Believe it or not, your eye can work pretty good too.
Any way, looking at that video, your chain is probably toast.  If the chain is the original, that is as long as they usually last.  Hard to tell from a video, though.  Check for tight links and dark fine rust around the O rings.  Also see how far the chain can be pulled from the back of the rear sprocket.  If you can expose more than 1/2 of the tooth you need a chain.  Do this in more than one section.  The definitive, PITA method of measuring chain stretch on your bike is 16 links should be no longer than 256.5 mm if you want to be anal.
Le Pirate
Quote from: howie on September 06, 2008, 03:14:33 PM
everything is square. I think you might be right about the chain. I think it's done  :'(
off to the parts store I guess. I need to buy a chain tool too
Quote from: Le Pirate on September 06, 2008, 04:25:23 PM
And sprockets.
http://www.ca-cycleworks.com   will set you up with your chain, sprockets, tool and,if you want, all the good advice you need.
Le Pirate
Quote from: howie on September 06, 2008, 06:38:55 PM
And sprockets.
I think i'm going to go ahead and bump it up to the 14 tooth in the front  8)
heard it's better to go more in the back sprocket and keep the 15 up front.
Le Pirate
Quote from: Raux on September 06, 2008, 08:18:00 PM
hrm...very interesting  8)
anyone do this....I've only heard of people doing the 14?
