Possible vapor lock? Or is this normal...
Started by corey, May 08, 2008, 05:51:57 PM
corey
So every time i remove my gas cap, it hisses and spits at me. Like an angry cobra. Psssht!
Is my tank vapor locking, or is this normal? It did this BEFORE i removed my emissions equipment as well.
duckwrench13
When you open the tank, there should be a little rubber bung-thingy sticking up next to the filler hole. Just use a pair of pliers, and yank that sucker out. It's there to prevent any overflow, or tip-over spill, from going out the vent line and straight to the ground. But since your emissions junk is gone, it doesn't matter. Removing it, in either case, will aid in venting the tank, and should reduce the pressure build up in the tank.  wt:
Of all the things I've lost, I miss my mind the most.
Gettin' blow'd up sucks!
Combat Veteran, Operation Enduring Freedom, Afghanistan 2006-2007
ScottRNelson
My ST2 started doing that, then I noticed that rubber "thingy" was misaligned.  It's now sitting in my "bag of stuff I might need sometime" in the left saddlebag.  No more problems.
corey
Thanks for the info guys! I'll check it out  ;D
