January 07, 2025, 12:57:35 PM
Removing Tank Decals
Topic: Removing Tank Decals (Read 2704 times)
nkryptit
September 11, 2008, 11:53:55 AM »
So...The "Monster" decal on my 696 is already starting to peel and look all around shitty. I'm looking to take them off, but don't want to leave a "Monster" shaped spot on my tank afterwords. Anyone ever take off decals without repainting the whole tank. What kind of solvent to use?
Bbrent
'08 S4RS Tricolore
Re: Removing Tank Decals
September 11, 2008, 02:48:30 PM »
Are the decals beneath the clearcoat? I have an S4RS and they were. I had to heat it up and pull really slowly to get them to lift. Then I had to sand, paint and reclear. I would be careful with solvents on you plastic. Wouldn't this be a warranty issue anyway?
September 11, 2008, 02:52:18 PM »
have you gone to the dealer, that quick seems like a warranty issue?
September 11, 2008, 04:48:41 PM »
sounds like a dark...
decals on top of the paint....
Last Edit: September 12, 2008, 02:59:52 AM by ducpainter
nkryptit
September 12, 2008, 06:29:39 AM »
Quote from: ducpainter on September 11, 2008, 04:48:41 PM
Indeed!
zLoki
Why yes, it is dangerous
September 12, 2008, 09:18:34 AM »
I'm about to take mine off but I'm simply replacing with a different color so there wont be that shadow you might be worried about (I have a dark also). I would suggest starting with soap and water and moving up to the likes of 409 before using any solvents on the tank. I'll be doing the same this week so I can report back on results.
Mostly stock '12 796
Sold - '09 696 with 30,000 miles
Murdered Monster
September 12, 2008, 09:41:49 AM »
'09 M696 Dark
nkryptit
September 12, 2008, 12:18:31 PM »
Quote from: zLoki on September 12, 2008, 09:18:34 AM
Thanks, I'd appreciate any input you can give!
S2daRk
September 12, 2008, 08:12:59 PM »
I replaced the decals on my dark tank not too long ago. I was also worried about having a Ducati "shadow" left behind. I removed only the "I" first, to see if the paint underneath would be darker. I was lucky no shadow whatsoever (my bike is 2 years old).
I used a heat gun to soften up the decals and removed them slowly. You don't need much heat, a hair dryer would be fine.
I then tried to remove the residue with warm water, but it wasn't working too well. So I tested a small spot underneath the seat with Goo Gone "
AUTOMOTIVE FORMULA
" (I don't recommend using the regular formula!). It worked great and I also used it when I removed the frame stickers.
Don't use paper towels to wipe off the sticky residue, it will scratch the tank. I used a soft microfiber towel that passed the "CD test" : Scrub the bottom of a CD with the towel and if the delicate CD surface doesn't get scratched, it's definitely safe to use on your tank.
dutchy73
September 13, 2008, 04:53:36 PM »
I pulled the decals off my 696 Dark a couple weeks ago. It did leave a little shadow, but all you need to do is get a very light automotive rubbing compound on a soft cloth and give it an easy once over. Don't swirl, just go back and forth in a straight line. Clean off the area well and apply your new decals. Make sure there is no dust, or the decals will show the particles.
Then take a liquid carnuba wax and apply to the entire tank. Don't use too much or it will cake around the decals. But do a light rub, dry, and then remove. You should be in business.
'09 696 Dark, Termi, Rizoma, CRG
zLoki
September 20, 2008, 02:13:35 PM »
Pulled mine off, there was no shadow, here's a pic.
